Date/Time: Fri, 27 Dec 2024 02:37:41 +0000
Example Custom Chart - Size Smaller than Main Price Graph
View Count: 623
[2016-03-07 19:39:21] |
Pinger - Posts: 33 |
Hi I want to create a study with a custom chart which displays 100 bars, for example, at the end of the main price graph, i.e. smaller than the main price graph. I have trawled the support board and looked at customchart.cpp but I can't find an example of how to do this. Any pointers would be much appreciated. Note: customchart.cpp appears to creates a custom chart of the same size as the main price graph, which is not what I want. Kind regards |
[2016-03-07 19:54:26] |
The custom chart that you want to create will have to replace the main price graph. It cannot be displayed at the same time. CustomChart.cpp is the example that you want to follow and it is the same size as the main price graph but that is only an example. The custom chart can be any number of bars. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-03-07 19:54:52
