Date/Time: Sun, 13 Sep 2026 13:08:56 +0000
Duplicate charts now results in data loading in a loop
View Count: 935
| [2016-03-07 18:23:41] |
| User884307 - Posts: 173 |
Hi, Im using the latest version of SC, although same thing happend in previous build also. When I duplicate one of my charts (created on an ongoing basis through the builds) it will duplicate it and load the data according to the days to load, it then briefly displays the duplicated chart BUT then it starts loading the data again in an ongoing loop. I wopuld appreciate some help on this cheers |
| [2016-03-07 18:25:33] |
Refer to: https://www.sierrachart.com/index.php?page=doc/helpdetails30.html#h30.3 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2016-03-07 19:12:12] |
TRhanks for reply.. My question is why did this not happen before when charts havent been altered at all, at any time ? |
| [2016-03-07 19:23:28] |
Ok, did have some referencing going on but with other charts so a bit strange but thanks to your guidence the problem is solver, MANY THANKS :-)
