Date/Time: Fri, 27 Dec 2024 01:30:38 +0000
Evening Session Mid-point
View Count: 888
[2016-03-05 14:47:44] |
Halco - Posts: 92 |
I use Daily OHLC HL Average to plot the mid-points for day and evening sessions. The day session study is fine but the evening session study also shows on the day session (giving me two mid-point lines on the day session) and I cannot find a way to set the options to prevent this. Is there a way to do this with Daily OHLC settings or is there another study/indicator that would plot only the evening session mid-point? Thanks.
[2016-03-05 19:21:59] |
You need to use the High / Low for Time Period study. Refer to: https://www.sierrachart.com/index.php?page=doc/doc_TechnicalStudiesReference.html#s313 To get the midpoint use Study Subgraphs Average: https://www.sierrachart.com/index.php?page=doc/doc_TechnicalStudiesReference.html#s164 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-03-05 19:22:16
