Date/Time: Fri, 27 Dec 2024 01:32:43 +0000
i want to share my setup files
View Count: 919
[2016-03-05 14:16:51] |
User21339 - Posts: 61 |
I want to share my configuration files with another sierracharts user. these in particular: shortcuts study collections and toolbars. where are they located? I looked in the data directory but it is too big to share in its entirety. and im not sure which files i can send that wont have my login details. |
[2016-03-05 19:23:28] |
What are "shortcuts"? Study collections are in the Data subfolder. Control Bars are located in the Sierra3.CFG file. For more information, refer to: Http://www.sierrachart.com/index.php?page=doc/helpdetails15.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-03-06 05:36:48] |
shortcuts i mean the chart shortcut menu
[2016-03-06 07:47:02] |
These are in the Sierra3.CFG file.
