Date/Time: Wed, 12 Feb 2025 09:38:28 +0000
Replay Hotkey
View Count: 938
[2016-03-05 07:13:50] |
User730732 - Posts: 12 |
Hi SC, Please consider adding a keyboard shortcut option for the play/pause button in replay mode. Best Regards, Thank you in advance! |
[2016-03-05 08:25:58] |
We will put this on our to do list, but it is not something easily implemented.
[2020-10-17 13:14:08] |
AwsM. - Posts: 4 |
Hi Did you put it on your list and if so when will it be implemented? Regards Date Time Of Last Edit: 2020-10-17 13:14:40
