Date/Time: Fri, 18 Sep 2026 05:31:56 +0000
numbers bars
View Count: 1072
| [2016-03-04 21:58:57] |
| User40526 - Posts: 166 |
When I try to create a 233 tick numbers bar chart for crude, it displays as one number bar for a whole day. I can't figure out what I am doing wrong. Chart Setting = Range Per Bar-True (in ticks) = 233 I can get 30 minute numbers bars and it displays just fine, but I want ticks to determine the bars. What other information can I provide that will help, if necessary. Thanks |
| [2016-03-04 22:19:08] |
That may make sense because that is an actual range of 2.33. If the market did not move more than that during the day, there will be just one bar.
