Date/Time: Sun, 20 Sep 2026 04:43:10 +0000
SC datafeed TLT symbol -no intraday data
View Count: 1544
| [2016-03-04 16:44:10] |
| User22396 - Posts: 191 |
can't seem to pull any historical intraday data from feb 2 to current date
| [2016-03-04 17:53:54] |
This is now solved. Apparently the symbol moved from NYSE to NASDAQ. This is a case that we do not have any automated handling of. Redownload the data in the chart with Edit >>Delete All Data and Download. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2016-03-30 14:23:30] |
Can you check to see if there is missing intraday data from 01feb-11feb I cant seem to download those days thanks |
| [2016-03-30 16:42:23] |
We see the data is missing. We need to patch this. Just give us about 30 minutes.
| [2016-03-30 17:47:24] |
The missing data is now filled in, but it only has been patched with 1 Minute data. We will work on adding tick data but that will take us about another 30 minutes to an hour. Follow the instructions here to download the missing data: Historical Intraday Data (Missing Data / Download Errors / Viewing More Data): Retrying the Download When There is Data in the Chart Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2016-03-30 19:51:02] |
We are not going to be able to fill in the tick by tick data until after the close because we need to do a software update which is best done after the market is closed. For now there is just one minute data during that period of time. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2016-03-31 02:00:12] |
We have now added the tick by tick data for where there was missing data previously.
