Date/Time: Fri, 27 Dec 2024 01:56:58 +0000
No DATA
View Count: 1124
[2016-03-03 09:50:48]
Meritus - Posts: 164
Hi Support
I have just activated the Real Time Data Connections and exchanges CME and ICE Europe to my account. I was previously using the data from my trading front end CTS T4 with SC and have decided to return to your feed as it is more stable. Anyway I have followed the setup instructions but I cannot see ICE data. There is an [M] after the CME symbols on the chart but not after the ICE symbol for which there is no data. The Data/Trade Service Settings "Service" remains set to my trading front end CTS T4 FIX [trading] as per instructions. Please advise. Thanks
Date Time Of Last Edit: 2016-03-03 10:10:20
[2016-03-03 10:20:38]
(Message Log removed)
Date Time Of Last Edit: 2016-03-03 10:34:05
[2016-03-03 10:35:06]
The message log provided is too long for us to work with.
It is going to be best to tell us what particular ICE symbols you are working with and we will make sure mapping a set up for them. They may not be currently set up.
Just give us the complete CTS T4 ICE symbols you are using and we will set these up for CTS T4 or see what the issue is.
Date Time Of Last Edit: 2016-03-03 10:35:54
[2016-03-03 10:42:34]
Thanks. The CTS ICE Europe symbols are those for
G.######00.ICE_IC
LS Gasoil G (IPE)... for example
G.20160300.ICE_IC March 2016
Date Time Of Last Edit: 2016-03-03 11:03:46
[2016-03-03 15:49:07]
Have you had a chance to set this up yet? I just need the above mentioned symbol LS Gasoil future. Thanks
[2016-03-03 17:01:35]
We are doing this now.
[2016-03-03 17:12:15]
The mapping for this market has now been set up. Follow the instructions here to update the Symbol Settings:
https://www.sierrachart.com/index.php?page=doc/doc_GlobalSymbolSettings.php#UpdateSettingsSteps
You may also want to re-download the data in the chart by selecting Edit >>Delete All Data and Download.
[2016-03-03 17:47:20]
I have followed your instructions and I still see no data but the [M] sign now appears after the name of the contract. Please see chart below which shows incomplete data.
http://www.sierrachart.com/image.php?l=1457027109284.png
Date Time Of Last Edit: 2016-03-03 17:47:43
[2016-03-03 17:55:56]
We apologize for this. There are two Gas Oil contracts on the ICE and set the mapping up for the wrong one.
Go to both the Historical and Intraday charts for G.######00.ICE_IC and re-download the data with Edit >Delete All Data and Download.
Let us know if it is correct.
[2016-03-03 18:16:41]
Thanks but it appears there is no difference to the chart. I have repeated the steps as instructed but there is no data in the LS Gasoil chart
[2016-03-03 18:23:15]
We are checking this now.
[2016-03-03 18:36:54]
CME data is all fine FYI, just ICE Europe specifically LS Gasoil. However I have just tried to open another ICE EUROPE contract (Brent) and that data is incomplete too and intraday data seems to stop on Feb 28th as shown in chart below
http://www.sierrachart.com/image.php?l=1457030107947.png
I pressed Delete All Data And Download for the Gasoil no data is being downloaded it has been blank for some time
Date Time Of Last Edit: 2016-03-03 18:40:12
[2016-03-03 18:53:33]
There are various Gas Oil contracts listed by both Barchart and CTS all with similar names. We think we have the mapping now correct.
We also forgot to tell you to update the Symbol Settings. Follow these instructions here:
http://www.sierrachart.com/index.php?page=doc/doc_GlobalSymbolSettings.php#UpdateSettings
After updating the Symbol Settings re-download the data in the charts again.
Date Time Of Last Edit: 2016-03-03 18:54:44
[2016-03-03 18:57:10]
ICE changed the rollover rules for Brent Crude oil. Refer to their website for more information.
If there is some other issue, let us know specifically what.
[2016-03-03 19:17:49]
Unfortunately there is no change. I have tried opening a new chart and deleting and downloading and I have tried deleting and downloading an existing gasoil chart. When I switch the chart from a historical to an intraday there is no data at all on the chart. When I open an intraday chart there is no data. I have followed your instructions as directed but I still have no data for the gasoil.
[2016-03-03 19:51:10]
We have confirmed the mapping is correct and does work:
http://www.sierrachart.com/image.php?l=1457034645803.png
Did you first update the Symbol Settings as explained here:
If there still is a problem we will use remote assistance to help you with this.
Date Time Of Last Edit: 2016-03-03 19:51:22
[2016-03-03 20:04:52]
I have followed this step again and still no dice. Idf you could please take a look I would really appreciate as I have done all you asked but am getting nowhere but that doesn't discount that I may have missed something but I doubt it. Thanks. Just let me know what I need to do
[2016-03-03 20:19:21]
We can call in about 10 minutes. Could you please make sure your telephone number here is up to date:
https://www.sierrachart.com/usercp.php?page=ManageAccountInfo
[2016-03-03 20:45:33]
The problem has been resolved with remote assistance.
There was one part of the documentation which was not totally clear which was leading to the problem.
