Date/Time: Fri, 27 Dec 2024 02:14:22 +0000
Numbers bars - AskV-BidV above bars
View Count: 1043
[2016-03-03 04:18:06] |
User60591 - Posts: 39 |
hi, just wanna ask if it's possible do get in future updates the possibility to show AskV-BidV above numbers bars. Same thing as Display Entire Profile Ask Volume - Bid Volume in Study settings for Volume by price just for each bar (preferably without AV-BV text) I know I can get it in numbers bars calculated values study, but its easier to follow delta above. thnx |
[2016-03-03 08:50:55] |
You can actually do this using this attached Study Collection. Follow the instructions here to use it: https://www.sierrachart.com/index.php?page=doc/doc_DLLUsage.html#UsingStudyCollection Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
Private File |
