Date/Time: Fri, 27 Dec 2024 01:51:54 +0000
change colour of 'show order fills'?
View Count: 1589
[2016-03-02 16:07:02] |
User60518 - Posts: 106 |
Hi, Is it possible to change the colours of the flags which show your order fills on the chart? currently burgundy/dark red for shorts and purple for longs on my charts. great feature, just not very visible on my chart. Cheers http://www.sierrachart.com/image.php?l=1456934806546.png |
[2016-03-02 19:54:48] |
This is documented in this section here: http://www.sierrachart.com/index.php?page=doc/doc_ChartTrading.html#DisplayingOrderFills Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
