Date/Time: Fri, 27 Dec 2024 01:52:43 +0000
HALF POINT OF THE DAY LINE
View Count: 705
[2016-03-02 15:08:58] |
AP - Posts: 117 |
Do we have anything (like an MA line does) that indicates half point of the day during the day? Ideally, I want to see the half point moving up or down (and not a static at the moment line /indicator)? |
[2016-03-02 20:11:18] |
This can be done by using the Daily OHLC study: http://www.sierrachart.com/index.php?page=doc/doc_TechnicalStudiesReference.html#s137 You will need to set the Graph High and Low Historically study Input to Yes. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
