Date/Time: Fri, 27 Dec 2024 02:35:27 +0000
No Sierra Internals Data this morning
View Count: 627
[2016-03-02 14:34:54] |
User56866 - Posts: 28 |
Watching TICK-NYSE and NISS-NYSE there is no data this morning, what's the problem? My usual CQG price data is coming through fine, the status bar is green. I have attached the log if it helps |
internals.txt - Attached On 2016-03-02 14:34:47 UTC - Size: 27.67 KB - 372 views |
[2016-03-02 14:47:55] |
There was a problem on one of the servers and this has now been resolved. You should be receiving the market statistics data now. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
