Date/Time: Fri, 27 Dec 2024 02:09:55 +0000
Auto retracement / projection - single horizontal line for current value?
View Count: 918
[2016-03-02 10:34:23]
T44 - Posts: 363
I don't wish to see the historical/past values for auto retracement/projection, just a horizontal line plotted at the current value. If I am displaying N+3 days of data on the chart and the time period unit in this study is N days, then the left hand side of the chart won't have accurate values, and I don't need to know what the values were N days ago, just today?
Is there a way to do this with the existing study, or should I set subgraph draw style to ignore and programatically reference the SG value from a custom horizontal line study?
[2016-03-02 19:51:19]
Use the Line at Last Bar to Edge Draw Style for the study Subgraphs with this study. Refer to:
http://www.sierrachart.com/index.php?page=doc/doc_ChartStudies.html#DrawStyle
[2016-03-03 08:01:47]
T44 - Posts: 363
Thank you, this works.
However, separately, I am getting incorrect values - this chart will illustrate.
I have retracements set to 30% and 70% of the 3 day range.
It seems to think the total range is the range of this current day. Not sure why this has happened.
Private File
[2016-03-03 08:33:12]
You need to refer to the documentation for this study to understand what it does and understand the settings:
https://www.sierrachart.com/index.php?page=doc/doc_TechnicalStudiesReference.html#s169
The screenshot does not mean anything to us. We do not know the Study Settings, cannot see all the chart data, and we do not know what you are expecting to see and why.
Date Time Of Last Edit: 2016-03-03 08:35:51
[2016-03-03 08:37:46]
Actually we think we know what you are saying. A 3 Day time period not a trailing 3 Days. It is 3 Days from Sunday as a point of reference.
Date Time Of Last Edit: 2016-03-03 08:38:13
[2016-03-03 10:44:11]
T44 - Posts: 363
Apologies, here are the settings.
I have circled in purple what I believe the issue to be.
Period high and period low is set to todays range when I have asked for 3 days.
Private File
