Date/Time: Tue, 06 Oct 2026 04:19:08 +0000
A couple ACSIL questions/requests.
View Count: 1014
| [2016-03-02 03:23:55] |
| enemyspy - Posts: 307 |
1. I am wondering it it would be possible to make the s_UseTool LineNumber member support GUID's. Currently using rand() with a Large range but occasionally the line numbers can coincide. 2. I am wondering if the usetool start and endpoints have to be fixed to a barIndex/datetime at a barIndex or if there is a way to use x y pixel coordinates, that you can refer me too. thanks for taking the time to answer this. |
| [2016-03-02 04:11:21] |
1. It is no longer recommended to set the s_UseTool::LineNumber because of potential conflicts. Let it be automatically assigned. All of the examples use it that way. Refer to: https://www.sierrachart.com/index.php?page=doc/doc_ACSILDrawingTools.html#LineNumber 2. No, you cannot use X and Y pixel coordinates. You can use direct GDI access for this: http://www.sierrachart.com/index.php?page=doc/doc_ACSILProgrammingConcepts.html#CustomFreeFormDrawing Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
