Date/Time: Fri, 27 Dec 2024 01:56:14 +0000
User Question - Balance not showing
View Count: 939
[2016-03-02 00:30:06] |
Sierra Chart - Max - Posts: 5769 |
Hi there, I am having an issue where my balance will not show up in Sierra charts under order and positions. I am an AMP trading user, do I need to do anything to get this to work? I have seen others mention something called Trans or something that they may be using.
Sierra Chart Support |
[2016-03-02 02:10:10] |
Refer to the documentation about this here: http://www.sierrachart.com/index.php?page=doc/doc_TradeStatusWindows.html#BalanceTab Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
