Date/Time: Fri, 27 Dec 2024 01:46:18 +0000
Rounding Issue with Percentage Price Oscillator
View Count: 1024
[2016-03-01 18:24:57] |
User126996 - Posts: 30 |
We are currently using a Percentage Price Oscillator and the it appears that the difference between the 2 simple moving averages is being rounded to the Thousandths (+3) decimal place. Is it possible to take that out to the +7 decimal places? If so how do we go about accomplishing this? The trading stratagy is based on precision math.
[2016-03-01 18:53:55] |
Yes. Refer to: Changing the Price/Value Display Format Also, no matter what the Value Format is set to, a trading strategy making reference to the data is always going to be using the full precision of the values. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-03-01 22:24:18] |
Thank you for the help!
