Date/Time: Fri, 27 Dec 2024 01:50:19 +0000
Message Log continually appears the last few days where it never has before and nuisance
View Count: 1029
[2016-03-01 17:11:01] |
User72436 - Posts: 10 |
Every time I use the DVP tool, the message log pops up. This has never happened until the last few days. I have completed the automatated replies you sent with no change. Software version: 1338 | 2016-03-01 11:59:54 Uses New Spreadsheets | 2016-03-01 11:59:54 Usage end date: 2016-11-26 | 2016-03-01 11:59:54 Enabled for: Advanced Features. | 2016-03-01 11:59:54 Enabled for: Advanced Features 2. | 2016-03-01 11:59:54 Enabled for: Sierra Chart Historical Data Service. | 2016-03-01 11:59:54 Allow Support for Sierra Chart Data Feeds is enabled. | 2016-03-01 11:59:54 Current selected Data/Trading service: Rithmic Trading | 2016-03-01 11:59:54 Chart Update Interval: 500 | 2016-03-01 11:59:54 Time Zone: -05:00:00 (EST-05EDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2016-03-01 11:59:54 2016-03-01 11:59:54 Local computer time | 2016-03-01 11:59:54 2016-03-01 16:59:54 Local computer time in UTC | 2016-03-01 11:59:54 2016-03-01 11:59:54 Local computer time in SC Time Zone | 2016-03-01 11:59:54 2016-03-01 17:00:04 Server time in UTC | 2016-03-01 11:59:54 Local computer UTC time and Server UTC time difference: 15 seconds. | 2016-03-01 11:59:54 Program path: C:\SierraChart\ | 2016-03-01 11:59:54 Data Files path: C:\SierraChart\Data\ | 2016-03-01 11:59:54 OS Version Number: 6.2 | 2016-03-01 11:59:54 Locale Information: C | 2016-03-01 11:59:54 (Message Log removed because posted portion was not relevant) Date Time Of Last Edit: 2016-03-01 17:53:39
[2016-03-01 17:52:56] |
Do the following: Update Sierra Chart to the current version: https://www.sierrachart.com/index.php?page=doc/download.php#FastUpdate After the update, make sure Global Settings >> General Settings >> General 2 >> Detailed Continuous Futures Contract Logging is unchecked. If you still have the problem, post the Message Log again at the time it opens. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-03-02 14:04:24] |
I updated to new version and unchecked the Detailed Continuous Futures Contract Logging, closed the program entirely. Upon re-opening and using the DVP tool the same Message Log that is copied below reappeared. Software version: 1374 | 2016-03-02 09:00:19 Uses New Spreadsheets | 2016-03-02 09:00:19 Usage end date: 2016-11-26 | 2016-03-02 09:00:19 Enabled for: Advanced Features. | 2016-03-02 09:00:19 Enabled for: Advanced Features 2. | 2016-03-02 09:00:19 Enabled for: Sierra Chart Historical Data Service. | 2016-03-02 09:00:19 Allow Support for Sierra Chart Data Feeds is enabled. | 2016-03-02 09:00:19 Current selected Data/Trading service: Rithmic Trading | 2016-03-02 09:00:19 Chart Update Interval: 500 | 2016-03-02 09:00:19 Time Zone: -05:00:00 (EST-05EDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2016-03-02 09:00:19 2016-03-02 09:00:24 Local computer time | 2016-03-02 09:00:19 2016-03-02 14:00:24 Local computer time in UTC | 2016-03-02 09:00:19 2016-03-02 09:00:24 Local computer time in SC Time Zone | 2016-03-02 09:00:19 2016-03-02 14:00:23 Server time in UTC | 2016-03-02 09:00:19 Local computer UTC time and Server UTC time difference: 1 seconds. | 2016-03-02 09:00:19 Program path: C:\SierraChart\ | 2016-03-02 09:00:19 Data Files path: C:\SierraChart\Data\ | 2016-03-02 09:00:19 OS Version Number: 6.2 | 2016-03-02 09:00:19 Locale Information: C | 2016-03-02 09:00:19 Checking for new symbol settings for rim | 2016-03-02 09:00:19 HTTPS connection to www.sierrachart.com:443 (0) | Resolved address sierrachart.com to IP 5.9.8.236. | 2016-03-02 09:00:19 HTTPS connection to www.sierrachart.com:443 (3) | Connected. | 2016-03-02 09:00:19 HTTPS connection to www.sierrachart.com:443 (3) | Starting TLS 1.2 connection. | 2016-03-02 09:00:19 HTTPS connection to www.sierrachart.com:443 (3) | Ignored Write event based on current socket state. | 2016-03-02 09:00:19 HTTPS connection to www.sierrachart.com:443 (3) | SSL connection established. | 2016-03-02 09:00:19 Symbol settings are up-to-date for rim | 2016-03-02 09:00:25 Files to Open on Start up | Opening file: COT.cht | 2016-03-02 09:00:27 CLH6-NYMEX [CB] Daily #2 | Performing historical Daily data download for symbol CLZ05 starting at last date in file. | 2016-03-02 09:00:27 CLH6-NYMEX [CB] Daily #2 | Performing historical Daily data download for symbol CLZ06 starting at last date in file. | 2016-03-02 09:00:27 CLH6-NYMEX [CB] Daily #2 | Performing historical Daily data download for symbol CLZ07 starting at last date in file. | 2016-03-02 09:00:27 CLH6-NYMEX [CB] Daily #2 | Performing historical Daily data download for symbol CLF08 starting at last date in file. | 2016-03-02 09:00:27 CLH6-NYMEX [CB] Daily #2 | Performing historical Daily data download for symbol CLZ11 starting at last date in file. | 2016-03-02 09:00:27 CLH6-NYMEX [CB] Daily #2 | Performing historical Daily data download for symbol CLH6-NYMEX starting at last date in file. | 2016-03-02 09:00:27 CLH6-NYMEX [CB] Daily #2 | File CLF08.dly has a volume of 0 at 2007-12-18. | 2016-03-02 09:00:27 CLH6-NYMEX [CB] Daily #2 | File CLZ07.dly has a volume of 0 at 2007-11-16. | 2016-03-02 09:00:27 CLH6-NYMEX [CB] Daily #2 | File CLZ06.dly has a volume of 0 at 2006-11-17. | 2016-03-02 09:00:27 CLH6-NYMEX [CB] Daily #2 | File CLZ05.dly has a volume of 0 at 2005-11-18. | 2016-03-02 09:00:27 CLH6-NYMEX [CB] Daily #2 | Waiting for historical downloads to complete with the IDs: 1, 2, 3, 4, 5, 6, | 2016-03-02 09:00:27 Files to Open on Start up | Opening file: Predatory.cht | 2016-03-02 09:00:27 Rithmic Trading | Using primary service for historical data for HGK6-COMEX | 2016-03-02 09:00:27 Rithmic Trading | Using primary service for historical data for ESH6-CME | 2016-03-02 09:00:27 Rithmic Trading | Using primary service for historical data for 6AH6-CME | 2016-03-02 09:00:27 Rithmic Trading | Using primary service for historical data for 6EH6-CME | 2016-03-02 09:00:27 Rithmic Trading | Using primary service for historical data for CLJ6-NYMEX | 2016-03-02 09:00:27 Rithmic Trading | Using primary service for historical data for ZBM6-CBOT | 2016-03-02 09:00:27 Rithmic Trading | Using primary service for historical data for 6CH6-CME | 2016-03-02 09:00:27 Rithmic Trading | Using primary service for historical data for ESH6-CME | 2016-03-02 09:00:27 Rithmic Trading | Using primary service for historical data for 6BH6-CME | 2016-03-02 09:00:27 Rithmic Trading | Using primary service for historical data for GCJ6-COMEX | 2016-03-02 09:00:27 Files to Open on Start up | Opening file: Mkt Structure.cht | 2016-03-02 09:00:27 Rithmic Trading | Using primary service for historical data for CLJ6-NYMEX | 2016-03-02 09:00:27 Rithmic Trading | Using primary service for historical data for 6EH6-CME | 2016-03-02 09:00:27 Rithmic Trading | Using primary service for historical data for GCJ6-COMEX | 2016-03-02 09:00:27 Rithmic Trading | Using primary service for historical data for DX FMH0016!-NYBOT | 2016-03-02 09:00:27 Rithmic Trading | Using primary service for historical data for 6AH6-CME | 2016-03-02 09:00:27 Rithmic Trading | Using primary service for historical data for 6BH6-CME | 2016-03-02 09:00:27 Rithmic Trading | Using primary service for historical data for 6CH6-CME | 2016-03-02 09:00:27 Rithmic Trading | Using primary service for historical data for HGK6-COMEX | 2016-03-02 09:00:27 Rithmic Trading | Using primary service for historical data for 6NH6-CME | 2016-03-02 09:00:27 Rithmic Trading | Using primary service for historical data for ESH6-CME | 2016-03-02 09:00:27 Rithmic Trading | Using primary service for historical data for ESH6-CME | 2016-03-02 09:00:27 Rithmic Trading | Using primary service for historical data for ZBM6-CBOT | 2016-03-02 09:00:27 Files to Open on Start up | Opening file: Mkt Comparison.cht | 2016-03-02 09:00:27 Rithmic Trading | Using primary service for historical data for ESH6-CME | 2016-03-02 09:00:27 Rithmic Trading | Using primary service for historical data for CLJ6-NYMEX | 2016-03-02 09:00:27 Rithmic Trading | Using primary service for historical data for CLJ6-NYMEX | 2016-03-02 09:00:27 Rithmic Trading | Using primary service for historical data for GCJ6-COMEX | 2016-03-02 09:00:27 Rithmic Trading | Using primary service for historical data for 6EH6-CME | 2016-03-02 09:00:27 Rithmic Trading | Using primary service for historical data for 6EH6-CME | 2016-03-02 09:00:27 Rithmic Trading | Using primary service for historical data for GCJ6-COMEX | 2016-03-02 09:00:27 Rithmic Trading | Using primary service for historical data for ZBM6-CBOT | 2016-03-02 09:00:27 Rithmic Trading | Using primary service for historical data for 6JH6-CME | 2016-03-02 09:00:27 Files to Open on Start up | Opening file: ES Session.cht | 2016-03-02 09:00:27 Rithmic Trading | Using primary service for historical data for ESH6-CME | 2016-03-02 09:00:27 Rithmic Trading | Using primary service for historical data for 6EH6-CME | 2016-03-02 09:00:27 Rithmic Trading | Using primary service for historical data for 6AH6-CME | 2016-03-02 09:00:27 Rithmic Trading | Using primary service for historical data for 6BH6-CME | 2016-03-02 09:00:27 Rithmic Trading | Using primary service for historical data for 6CH6-CME | 2016-03-02 09:00:27 Rithmic Trading | Using primary service for historical data for GCJ6-COMEX | 2016-03-02 09:00:27 Rithmic Trading | Using primary service for historical data for HGK6-COMEX | 2016-03-02 09:00:27 Rithmic Trading | Using primary service for historical data for 6SH6-CME | 2016-03-02 09:00:27 Rithmic Trading | Using primary service for historical data for ZBM6-CBOT | 2016-03-02 09:00:27 Rithmic Trading | Using primary service for historical data for CLJ6-NYMEX | 2016-03-02 09:00:27 HD Request # 2 | Downloading Historical Daily chart data for CLZ05. Starting date: 2005-11-17. Service: rim | 2016-03-02 09:00:27 HD Request # 2 | Requesting historical Daily data for CLZ05 starting at 2005-11-16 | 2016-03-02 09:00:27 HTTPS connection to www.sierrachart.com:443 (3) | SSL connection closed by remote side. | 2016-03-02 09:00:27 HTTPS connection to www.sierrachart.com:443 (3) | Connection gracefully closed by remote side. | 2016-03-02 09:00:27 HTTPS connection to www.sierrachart.com:443 (3) | SSL object has been freed. SSL state is now disconnected. | 2016-03-02 09:00:27 HTTPS connection to www.sierrachart.com:443 (3) | Shutdown and closed. | 2016-03-02 09:00:27 HTTP connection to ds01.ddfplus.com:80 (0) | Resolved address ds01.ddfplus.com to IP 8.18.161.123. | 2016-03-02 09:00:27 HTTP connection to ds01.ddfplus.com:80 (4) | Connected. | 2016-03-02 09:00:40 HD Request # 2 | Receiving historical Daily data for CLZ05 starting at 2005-11-17 | 2016-03-02 09:00:40 Writing historical Daily data for CLZ05 to the file CLZ05.dly | 2016-03-02 09:00:40 HD Request # 2 | Received 3 records from 2005-11-17 00:00:00 to 2005-11-18 00:00:00 (2.0 days) and wrote 2 records for CLZ05 | 2016-03-02 09:00:40 HD Request # 2 | Daily download COMPLETE for CLZ05. Completion time: 0s. Unique request ID: 1 | 2016-03-02 09:00:40 Removed historical data download ID 1 | 2016-03-02 09:00:40 HD Request # 3 | Downloading Historical Daily chart data for CLZ06. Starting date: 2006-11-16. Service: rim | 2016-03-02 09:00:40 HD Request # 3 | Requesting historical Daily data for CLZ06 starting at 2006-11-15 | 2016-03-02 09:00:40 HD Request # 3 | Receiving historical Daily data for CLZ06 starting at 2006-11-16 | 2016-03-02 09:00:40 Writing historical Daily data for CLZ06 to the file CLZ06.dly | 2016-03-02 09:00:40 HD Request # 3 | Received 3 records from 2006-11-16 00:00:00 to 2006-11-17 00:00:00 (2.0 days) and wrote 2 records for CLZ06 | 2016-03-02 09:00:40 HD Request # 3 | Daily download COMPLETE for CLZ06. Completion time: 1s. Unique request ID: 2 | 2016-03-02 09:00:40 Removed historical data download ID 2 | 2016-03-02 09:00:40 HD Request # 4 | Downloading Historical Daily chart data for CLZ07. Starting date: 2007-11-15. Service: rim | 2016-03-02 09:00:40 HD Request # 4 | Requesting historical Daily data for CLZ07 starting at 2007-11-14 | 2016-03-02 09:00:40 HD Request # 4 | Receiving historical Daily data for CLZ07 starting at 2007-11-15 | 2016-03-02 09:00:40 Writing historical Daily data for CLZ07 to the file CLZ07.dly | 2016-03-02 09:00:40 HD Request # 4 | Received 3 records from 2007-11-15 00:00:00 to 2007-11-16 00:00:00 (2.0 days) and wrote 2 records for CLZ07 | 2016-03-02 09:00:40 HD Request # 4 | Daily download COMPLETE for CLZ07. Completion time: 0s. Unique request ID: 3 | 2016-03-02 09:00:40 Removed historical data download ID 3 | 2016-03-02 09:00:40 HD Request # 5 | Downloading Historical Daily chart data for CLF08. Starting date: 2007-12-17. Service: rim | 2016-03-02 09:00:40 HD Request # 5 | Requesting historical Daily data for CLF08 starting at 2007-12-16 | 2016-03-02 09:00:40 HD Request # 5 | Receiving historical Daily data for CLF08 starting at 2007-12-17 | 2016-03-02 09:00:40 Writing historical Daily data for CLF08 to the file CLF08.dly | 2016-03-02 09:00:40 HD Request # 5 | Received 2 records from 2007-12-17 00:00:00 to 2007-12-18 00:00:00 (2.0 days) and wrote 2 records for CLF08 | 2016-03-02 09:00:40 HD Request # 5 | Daily download COMPLETE for CLF08. Completion time: 0s. Unique request ID: 4 | 2016-03-02 09:00:40 Removed historical data download ID 4 | 2016-03-02 09:00:40 HD Request # 6 | Downloading Historical Daily chart data for CLZ11. Starting date: 2011-11-17. Service: rim | 2016-03-02 09:00:40 HD Request # 6 | Requesting historical Daily data for CLZ11 starting at 2011-11-16 | 2016-03-02 09:00:40 HD Request # 6 | Receiving historical Daily data for CLZ11 starting at 2011-11-17 | 2016-03-02 09:00:40 Writing historical Daily data for CLZ11 to the file CLZ11.dly | 2016-03-02 09:00:40 HD Request # 6 | Received 3 records from 2011-11-17 00:00:00 to 2011-11-18 00:00:00 (2.0 days) and wrote 2 records for CLZ11 | 2016-03-02 09:00:40 HD Request # 6 | Daily download COMPLETE for CLZ11. Completion time: 0s. Unique request ID: 5 | 2016-03-02 09:00:40 Removed historical data download ID 5 | 2016-03-02 09:00:40 HD Request # 7 | Downloading Historical Daily chart data for CLH6-NYMEX. Starting date: 2016-02-19. Service: rim | 2016-03-02 09:00:40 HD Request # 7 | Requesting historical Daily data for CLH16 starting at 2016-02-18 | 2016-03-02 09:00:40 Rithmic Trading | Port for executable: 61812 | 2016-03-02 09:00:41 Listening socket (1436), port 61812 | Closed. | 2016-03-02 09:00:41 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2016-03-02 09:00:41 HD Request # 7 | Receiving historical Daily data for CLH6-NYMEX starting at 2016-02-19 | 2016-03-02 09:00:41 Writing historical Daily data for CLH6-NYMEX to the file CLH6-NYMEX.dly | 2016-03-02 09:00:41 HD Request # 7 | Received 3 records from 2016-02-19 00:00:00 to 2016-02-22 00:00:00 (4.0 days) and wrote 2 records for CLH6-NYMEX | 2016-03-02 09:00:41 HD Request # 7 | Daily download COMPLETE for CLH6-NYMEX. Completion time: 0s. Unique request ID: 6 | 2016-03-02 09:00:41 Removed historical data download ID 6 | 2016-03-02 09:00:41 HD Request # 8 | Downloading Historical Daily chart data for 6EH6-CME. Starting date: 2016-03-01. Service: rim | 2016-03-02 09:00:41 HD Request # 8 | Requesting historical Daily data for E6H16 starting at 2016-02-29 | 2016-03-02 09:00:41 CLH6-NYMEX [CB] Daily #2 | Download is complete for all contract months in chart. Proceeding with data load. | 2016-03-02 09:00:41 CLH6-NYMEX [CB] Daily #2 | Reloading chart. | 2016-03-02 09:00:41 HD Request # 8 | Receiving historical Daily data for 6EH6-CME starting at 2016-03-01 | 2016-03-02 09:00:41 Writing historical Daily data for 6EH6-CME to the file 6EH6-CME.dly | 2016-03-02 09:00:41 HD Request # 8 | Received 3 records from 2016-03-01 00:00:00 to 2016-03-02 00:00:00 (2.0 days) and wrote 2 records for 6EH6-CME | 2016-03-02 09:00:41 HD Request # 8 | Daily download COMPLETE for 6EH6-CME. Completion time: 4s. Unique request ID: 7 | 2016-03-02 09:00:41 Removed historical data download ID 7 | 2016-03-02 09:00:41 HD Request # 9 | Downloading Historical Daily chart data for ESH6-CME. Starting date: 2016-03-01. Service: rim | 2016-03-02 09:00:41 HD Request # 9 | Requesting historical Daily data for ESH16 starting at 2016-02-29 | 2016-03-02 09:00:41 6EH6-CME [CB] Daily #1 | Reloading chart. | 2016-03-02 09:00:46 HD Request # 9 | Receiving historical Daily data for ESH6-CME starting at 2016-03-01 | 2016-03-02 09:00:46 Writing historical Daily data for ESH6-CME to the file ESH6-CME.dly | 2016-03-02 09:00:46 HD Request # 9 | Received 3 records from 2016-03-01 00:00:00 to 2016-03-02 00:00:00 (2.0 days) and wrote 2 records for ESH6-CME | 2016-03-02 09:00:46 HD Request # 9 | Daily download COMPLETE for ESH6-CME. Completion time: 1s. Unique request ID: 8 | 2016-03-02 09:00:46 Removed historical data download ID 8 | 2016-03-02 09:00:46 HD Request # 10 | Downloading Historical Daily chart data for ZBH6-CBOT. Starting date: 2016-03-01. Service: rim | 2016-03-02 09:00:46 HD Request # 10 | Requesting historical Daily data for ZBH16 starting at 2016-02-29 | 2016-03-02 09:00:46 Rithmic Trading | Connecting to the server 127.0.0.1. Port 61812 | 2016-03-02 09:00:46 Socket (5) | Connected. | 2016-03-02 09:00:46 Rithmic Trading | Connected to server. | 2016-03-02 09:00:46 Rithmic Trading | Sending Encoding Request to server | 2016-03-02 09:00:46 Rithmic Trading | Setting DTC Encoding to Binary | 2016-03-02 09:00:46 Rithmic Trading | Sending logon request message. | 2016-03-02 09:00:46 Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2016-03-02 09:00:46 Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2016-03-02 09:00:46 Rithmic Trading | Message from server: Connecting to Rithmic 01 US server. | 2016-03-02 09:00:46 ESH6-CME [CB] Daily #4 | Reloading chart. | 2016-03-02 09:00:46 HD Request # 10 | Receiving historical Daily data for ZBH6-CBOT starting at 2016-03-01 | 2016-03-02 09:00:46 Writing historical Daily data for ZBH6-CBOT to the file ZBH6-CBOT.dly | 2016-03-02 09:00:46 HD Request # 10 | Received 3 records from 2016-03-01 00:00:00 to 2016-03-02 00:00:00 (2.0 days) and wrote 2 records for ZBH6-CBOT | 2016-03-02 09:00:46 HD Request # 10 | Daily download COMPLETE for ZBH6-CBOT. Completion time: 0s. Unique request ID: 9 | 2016-03-02 09:00:46 Removed historical data download ID 9 | 2016-03-02 09:00:46 HD Request # 11 | Downloading Historical Daily chart data for 6AH6-CME. Starting date: 2016-03-01. Service: rim | 2016-03-02 09:00:46 HD Request # 11 | Requesting historical Daily data for A6H16 starting at 2016-02-29 | 2016-03-02 09:00:46 ZBH6-CBOT [CB] Daily #7 | Reloading chart. | 2016-03-02 09:00:47 HD Request # 11 | Receiving historical Daily data for 6AH6-CME starting at 2016-03-01 | 2016-03-02 09:00:47 Writing historical Daily data for 6AH6-CME to the file 6AH6-CME.dly | 2016-03-02 09:00:47 HD Request # 11 | Received 3 records from 2016-03-01 00:00:00 to 2016-03-02 00:00:00 (2.0 days) and wrote 2 records for 6AH6-CME | 2016-03-02 09:00:47 HD Request # 11 | Daily download COMPLETE for 6AH6-CME. Completion time: 0s. Unique request ID: 10 | 2016-03-02 09:00:47 Removed historical data download ID 10 | 2016-03-02 09:00:47 HD Request # 12 | Downloading Historical Daily chart data for 6CH6-CME. Starting date: 2016-03-01. Service: rim | 2016-03-02 09:00:47 HD Request # 12 | Requesting historical Daily data for D6H16 starting at 2016-02-29 | 2016-03-02 09:00:47 6AH6-CME [CB] Daily #8 | Reloading chart. | 2016-03-02 09:00:47 HD Request # 12 | Receiving historical Daily data for 6CH6-CME starting at 2016-03-01 | 2016-03-02 09:00:47 Writing historical Daily data for 6CH6-CME to the file 6CH6-CME.dly | 2016-03-02 09:00:47 HD Request # 12 | Received 3 records from 2016-03-01 00:00:00 to 2016-03-02 00:00:00 (2.0 days) and wrote 2 records for 6CH6-CME | 2016-03-02 09:00:47 HD Request # 12 | Daily download COMPLETE for 6CH6-CME. Completion time: 1s. Unique request ID: 11 | 2016-03-02 09:00:47 Removed historical data download ID 11 | 2016-03-02 09:00:47 Rithmic Trading | Message from server: Server Alert: Market Data Connection Opened | 2016-03-02 09:00:47 Rithmic Trading | Message from server: Server Alert: Market Data Connection Login Complete. Result text: "ok" | 2016-03-02 09:00:47 HD Request # 13 | Downloading Historical Daily chart data for HGH6-COMEX. Starting date: 2016-03-01. Service: rim | 2016-03-02 09:00:47 HD Request # 13 | Requesting historical Daily data for HGH16 starting at 2016-02-29 | 2016-03-02 09:00:47 6CH6-CME [CB] Daily #9 | Reloading chart. | 2016-03-02 09:00:48 HD Request # 13 | Receiving historical Daily data for HGH6-COMEX starting at 2016-03-01 | 2016-03-02 09:00:48 Writing historical Daily data for HGH6-COMEX to the file HGH6-COMEX.dly | 2016-03-02 09:00:48 HD Request # 13 | Received 3 records from 2016-03-01 00:00:00 to 2016-03-02 00:00:00 (2.0 days) and wrote 2 records for HGH6-COMEX | 2016-03-02 09:00:48 HD Request # 13 | Daily download COMPLETE for HGH6-COMEX. Completion time: 0s. Unique request ID: 12 | 2016-03-02 09:00:48 Removed historical data download ID 12 | 2016-03-02 09:00:48 Rithmic Trading | Message from server: Server Alert: Trading System Connection Opened | 2016-03-02 09:00:48 Rithmic Trading | Message from server: Server Alert: Trading System Connection Login Complete. Result text: "ok" | 2016-03-02 09:00:48 HD Request # 14 | Downloading Historical Daily chart data for GCJ6-COMEX. Starting date: 2016-03-01. Service: rim | 2016-03-02 09:00:48 HD Request # 14 | Requesting historical Daily data for GCJ16 starting at 2016-02-29 | 2016-03-02 09:00:48 HGH6-COMEX [CB] Daily #3 | Reloading chart. | 2016-03-02 09:00:48 Rithmic Trading | Message from server: Server Alert: PnL Connection Opened | 2016-03-02 09:00:48 Rithmic Trading | Message from server: Server Alert: PnL Connection Login Complete. Result text: "ok" | 2016-03-02 09:00:48 Rithmic Trading | Message from server: Server Alert: Intraday History Connection Opened | 2016-03-02 09:00:48 Rithmic Trading | Message from server: Server Alert: Intraday History Connection Login Complete. Result text: "ok" | 2016-03-02 09:00:48 Rithmic Trading | Received logon response. | 2016-03-02 09:00:48 Rithmic Trading | Server Name: SC DTC Bridge. | 2016-03-02 09:00:48 Rithmic Trading | Server protocol version: 7. Client protocol version: 7 | 2016-03-02 09:00:48 Rithmic Trading | Successfully connected. IB='ForemostTrading'. | 2016-03-02 09:00:48 Rithmic Trading | Trading is supported. | 2016-03-02 09:00:48 Rithmic Trading | Order cancel and replace is supported. | 2016-03-02 09:00:48 Rithmic Trading | Connected to data and trading server. | 2016-03-02 09:00:48 Rithmic Trading | OCO Orders supported. | 2016-03-02 09:00:48 HD Request # 14 | Receiving historical Daily data for GCJ6-COMEX starting at 2016-03-01 | 2016-03-02 09:00:48 Writing historical Daily data for GCJ6-COMEX to the file GCJ6-COMEX.dly | 2016-03-02 09:00:48 HD Request # 14 | Received 3 records from 2016-03-01 00:00:00 to 2016-03-02 00:00:00 (2.0 days) and wrote 2 records for GCJ6-COMEX | 2016-03-02 09:00:48 HD Request # 14 | Daily download COMPLETE for GCJ6-COMEX. Completion time: 0s. Unique request ID: 13 | 2016-03-02 09:00:48 Removed historical data download ID 13 | 2016-03-02 09:00:48 HD Request # 15 | Downloading Historical Daily chart data for 6BH6-CME. Starting date: 2016-03-01. Service: rim | 2016-03-02 09:00:48 HD Request # 15 | Requesting historical Daily data for B6H16 starting at 2016-02-29 | 2016-03-02 09:00:48 Rithmic Trading | Starting real-time market data updates for: 6AH6-CME. ID: 2 | 2016-03-02 09:00:50 Intraday data recording state for symbol 6AH6-CME is set to download 'Pending'. | 2016-03-02 09:00:50 HD Request # 16 | Downloading Intraday chart data for 6AH6-CME to the file 6AH6-CME.scid. Service: cme | 2016-03-02 09:00:50 HD Request # 16 | Download start Date-Time: 2016-03-02 08:59:52.000 | 2016-03-02 09:00:50 HD Request # 16 | Error downloading historical Intraday data for 6AH6-CME. Not downloading Intraday data for symbol 6AH6-CME. Less than 10 minutes since last record Date-Time. | 2016-03-02 09:00:50 HD Request # 16 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for 6AH6-CME | 2016-03-02 09:00:50 HD Request # 16 | Intraday download COMPLETE for 6AH6-CME. Completion time: 0s. Unique request ID: 15 | 2016-03-02 09:00:50 Removed historical data download ID 15 | 2016-03-02 09:00:50 Real-time Intraday chart data file updates started for 6AH6-CME | 2016-03-02 09:00:50 Opened cached Intraday file: C:\SierraChart\Data\6AH6-CME.scid | 2016-03-02 09:00:50 Intraday chart data file opened for 6AH6-CME | 2016-03-02 09:00:50 Rithmic Trading | Using primary service for historical data for 6AH6-CME | 2016-03-02 09:00:50 Intraday data recording state for symbol 6AH6-CME is set to download 'Pending'. | 2016-03-02 09:00:50 HD Request # 17 | Downloading Intraday chart data for 6AH6-CME to the file 6AH6-CME.scid. Service: rim | 2016-03-02 09:00:50 HD Request # 17 | Download start Date-Time: 2016-03-02 08:59:52.000 | 2016-03-02 09:00:50 HD Request # 17 | Sending historical data request. Start Date-Time: 2016-03-02 08:59:52. Record interval: 0. Symbol: 6AH6-CME | 2016-03-02 09:00:50 Rithmic Trading | Starting real-time market data updates for: CLH6-NYMEX. ID: 3 | 2016-03-02 09:00:50 Rithmic Trading | Message from server: Requesting historical Tick data. | 2016-03-02 09:00:50 Rithmic Trading | Starting real-time market data updates for: 6CH6-CME. ID: 4 | 2016-03-02 09:00:50 Rithmic Trading | Starting real-time market data updates for: CLJ6-NYMEX. ID: 5 | 2016-03-02 09:00:50 Intraday data recording state for symbol CLJ6-NYMEX is set to download 'Pending'. | 2016-03-02 09:00:50 HD Request # 18 | Downloading Intraday chart data for CLJ6-NYMEX to the file CLJ6-NYMEX.scid. Service: nymex | 2016-03-02 09:00:50 HD Request # 18 | Download start Date-Time: 2016-03-02 08:59:51.000 | 2016-03-02 09:00:50 HD Request # 18 | Error downloading historical Intraday data for CLJ6-NYMEX. Not downloading Intraday data for symbol CLJ6-NYMEX. Less than 10 minutes since last record Date-Time. | 2016-03-02 09:00:50 HD Request # 18 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for CLJ6-NYMEX | 2016-03-02 09:00:50 HD Request # 18 | Intraday download COMPLETE for CLJ6-NYMEX. Completion time: 0s. Unique request ID: 17 | 2016-03-02 09:00:50 Removed historical data download ID 17 | 2016-03-02 09:00:50 Real-time Intraday chart data file updates started for CLJ6-NYMEX | 2016-03-02 09:00:50 Opened cached Intraday file: C:\SierraChart\Data\CLJ6-NYMEX.scid | 2016-03-02 09:00:50 Intraday chart data file opened for CLJ6-NYMEX | 2016-03-02 09:00:50 Rithmic Trading | Using primary service for historical data for CLJ6-NYMEX | 2016-03-02 09:00:50 Intraday data recording state for symbol CLJ6-NYMEX is set to download 'Pending'. | 2016-03-02 09:00:50 Rithmic Trading | Starting real-time market data updates for: 6BH6-CME. ID: 1 | 2016-03-02 09:00:50 Rithmic Trading | Starting real-time market data updates for: ESH6-CME. ID: 6 | 2016-03-02 09:00:50 Intraday data recording state for symbol ESH6-CME is set to download 'Pending'. | 2016-03-02 09:00:50 HD Request # 19 | Downloading Intraday chart data for ESH6-CME to the file ESH6-CME.scid. Service: cme | 2016-03-02 09:00:50 HD Request # 19 | Download start Date-Time: 2016-03-02 08:59:51.000 | 2016-03-02 09:00:50 HD Request # 19 | Error downloading historical Intraday data for ESH6-CME. Not downloading Intraday data for symbol ESH6-CME. Less than 10 minutes since last record Date-Time. | 2016-03-02 09:00:50 HD Request # 19 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ESH6-CME | 2016-03-02 09:00:50 HD Request # 19 | Intraday download COMPLETE for ESH6-CME. Completion time: 0s. Unique request ID: 19 | 2016-03-02 09:00:50 Removed historical data download ID 19 | 2016-03-02 09:00:50 Real-time Intraday chart data file updates started for ESH6-CME | 2016-03-02 09:00:50 Opened cached Intraday file: C:\SierraChart\Data\ESH6-CME.scid | 2016-03-02 09:00:50 Intraday chart data file opened for ESH6-CME | 2016-03-02 09:00:50 Rithmic Trading | Using primary service for historical data for ESH6-CME | 2016-03-02 09:00:50 Intraday data recording state for symbol ESH6-CME is set to download 'Pending'. | 2016-03-02 09:00:50 Intraday data recording state for symbol 6CH6-CME is set to download 'Pending'. | 2016-03-02 09:00:50 HD Request # 20 | Downloading Intraday chart data for 6CH6-CME to the file 6CH6-CME.scid. Service: cme | 2016-03-02 09:00:50 HD Request # 20 | Download start Date-Time: 2016-03-02 08:59:41.000 | 2016-03-02 09:00:50 HD Request # 20 | Error downloading historical Intraday data for 6CH6-CME. Not downloading Intraday data for symbol 6CH6-CME. Less than 10 minutes since last record Date-Time. | 2016-03-02 09:00:50 HD Request # 20 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for 6CH6-CME | 2016-03-02 09:00:50 HD Request # 20 | Intraday download COMPLETE for 6CH6-CME. Completion time: 0s. Unique request ID: 21 | 2016-03-02 09:00:50 Removed historical data download ID 21 | 2016-03-02 09:00:50 Real-time Intraday chart data file updates started for 6CH6-CME | 2016-03-02 09:00:50 Opened cached Intraday file: C:\SierraChart\Data\6CH6-CME.scid | 2016-03-02 09:00:50 Intraday chart data file opened for 6CH6-CME | 2016-03-02 09:00:50 Rithmic Trading | Using primary service for historical data for 6CH6-CME | 2016-03-02 09:00:50 Intraday data recording state for symbol 6CH6-CME is set to download 'Pending'. | 2016-03-02 09:00:50 Rithmic Trading | Starting real-time market data updates for: 6EH6-CME. ID: 7 | 2016-03-02 09:00:50 Intraday data recording state for symbol 6EH6-CME is set to download 'Pending'. | 2016-03-02 09:00:50 HD Request # 21 | Downloading Intraday chart data for 6EH6-CME to the file 6EH6-CME.scid. Service: cme | 2016-03-02 09:00:50 HD Request # 21 | Download start Date-Time: 2016-03-02 08:59:50.000 | 2016-03-02 09:00:50 HD Request # 21 | Error downloading historical Intraday data for 6EH6-CME. Not downloading Intraday data for symbol 6EH6-CME. Less than 10 minutes since last record Date-Time. | 2016-03-02 09:00:50 HD Request # 21 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for 6EH6-CME | 2016-03-02 09:00:50 HD Request # 21 | Intraday download COMPLETE for 6EH6-CME. Completion time: 0s. Unique request ID: 23 | 2016-03-02 09:00:50 Removed historical data download ID 23 | 2016-03-02 09:00:50 Real-time Intraday chart data file updates started for 6EH6-CME | 2016-03-02 09:00:50 Opened cached Intraday file: C:\SierraChart\Data\6EH6-CME.scid | 2016-03-02 09:00:50 Intraday chart data file opened for 6EH6-CME | 2016-03-02 09:00:50 Rithmic Trading | Using primary service for historical data for 6EH6-CME | 2016-03-02 09:00:50 Intraday data recording state for symbol 6EH6-CME is set to download 'Pending'. | 2016-03-02 09:00:50 Rithmic Trading | Starting real-time market data updates for: HGK6-COMEX. ID: 8 | 2016-03-02 09:00:50 Intraday data recording state for symbol HGK6-COMEX is set to download 'Pending'. | 2016-03-02 09:00:50 Rithmic Trading | Message from server: Server Alert: The subscription to this instrument has been aborted. Dependent network services and/or data were not available. | 2016-03-02 09:00:50 Symbol Error - CLH6-NYMEX is unknown, unavailable, or improperly formatted. | 2016-03-02 09:00:50 HD Request # 22 | Downloading Intraday chart data for HGK6-COMEX to the file HGK6-COMEX.scid. Service: comex | 2016-03-02 09:00:50 HD Request # 22 | Download start Date-Time: 2016-03-02 08:59:45.000 | 2016-03-02 09:00:50 HD Request # 22 | Error downloading historical Intraday data for HGK6-COMEX. Not downloading Intraday data for symbol HGK6-COMEX. Less than 10 minutes since last record Date-Time. | 2016-03-02 09:00:50 HD Request # 22 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for HGK6-COMEX | 2016-03-02 09:00:50 HD Request # 22 | Intraday download COMPLETE for HGK6-COMEX. Completion time: 0s. Unique request ID: 25 | 2016-03-02 09:00:50 Removed historical data download ID 25 | 2016-03-02 09:00:50 Real-time Intraday chart data file updates started for HGK6-COMEX | 2016-03-02 09:00:50 Opened cached Intraday file: C:\SierraChart\Data\HGK6-COMEX.scid | 2016-03-02 09:00:50 Intraday chart data file opened for HGK6-COMEX | 2016-03-02 09:00:50 Rithmic Trading | Using primary service for historical data for HGK6-COMEX | 2016-03-02 09:00:50 Intraday data recording state for symbol HGK6-COMEX is set to download 'Pending'. | 2016-03-02 09:00:50 HD Request # 15 | Receiving historical Daily data for 6BH6-CME starting at 2016-03-01 | 2016-03-02 09:00:50 Writing historical Daily data for 6BH6-CME to the file 6BH6-CME.dly | 2016-03-02 09:00:50 HD Request # 15 | Received 3 records from 2016-03-01 00:00:00 to 2016-03-02 00:00:00 (2.0 days) and wrote 2 records for 6BH6-CME | 2016-03-02 09:00:50 HD Request # 15 | Daily download COMPLETE for 6BH6-CME. Completion time: 0s. Unique request ID: 14 | 2016-03-02 09:00:50 Removed historical data download ID 14 | 2016-03-02 09:00:50 Rithmic Trading | Starting real-time market data updates for: ZBM6-CBOT. ID: 9 | 2016-03-02 09:00:50 Intraday data recording state for symbol ZBM6-CBOT is set to download 'Pending'. | 2016-03-02 09:00:50 HD Request # 23 | Downloading Intraday chart data for ZBM6-CBOT to the file ZBM6-CBOT.scid. Service: cbot | 2016-03-02 09:00:50 HD Request # 23 | Download start Date-Time: 2016-03-02 08:59:40.000 | 2016-03-02 09:00:50 HD Request # 23 | Error downloading historical Intraday data for ZBM6-CBOT. Not downloading Intraday data for symbol ZBM6-CBOT. Less than 10 minutes since last record Date-Time. | 2016-03-02 09:00:50 HD Request # 23 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ZBM6-CBOT | 2016-03-02 09:00:50 HD Request # 23 | Intraday download COMPLETE for ZBM6-CBOT. Completion time: 0s. Unique request ID: 27 | 2016-03-02 09:00:50 Removed historical data download ID 27 | 2016-03-02 09:00:50 Real-time Intraday chart data file updates started for ZBM6-CBOT | 2016-03-02 09:00:50 Opened cached Intraday file: C:\SierraChart\Data\ZBM6-CBOT.scid | 2016-03-02 09:00:50 Intraday chart data file opened for ZBM6-CBOT | 2016-03-02 09:00:50 Rithmic Trading | Using primary service for historical data for ZBM6-CBOT | 2016-03-02 09:00:50 Intraday data recording state for symbol ZBM6-CBOT is set to download 'Pending'. | 2016-03-02 09:00:50 Intraday data recording state for symbol 6BH6-CME is set to download 'Pending'. | 2016-03-02 09:00:50 HD Request # 24 | Downloading Intraday chart data for 6BH6-CME to the file 6BH6-CME.scid. Service: cme | 2016-03-02 09:00:50 HD Request # 24 | Download start Date-Time: 2016-03-02 08:59:50.000 | 2016-03-02 09:00:50 HD Request # 24 | Error downloading historical Intraday data for 6BH6-CME. Not downloading Intraday data for symbol 6BH6-CME. Less than 10 minutes since last record Date-Time. | 2016-03-02 09:00:50 HD Request # 24 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for 6BH6-CME | 2016-03-02 09:00:50 HD Request # 24 | Intraday download COMPLETE for 6BH6-CME. Completion time: 0s. Unique request ID: 29 | 2016-03-02 09:00:50 Removed historical data download ID 29 | 2016-03-02 09:00:50 Real-time Intraday chart data file updates started for 6BH6-CME | 2016-03-02 09:00:50 Opened cached Intraday file: C:\SierraChart\Data\6BH6-CME.scid | 2016-03-02 09:00:50 Intraday chart data file opened for 6BH6-CME | 2016-03-02 09:00:50 Rithmic Trading | Using primary service for historical data for 6BH6-CME | 2016-03-02 09:00:50 Intraday data recording state for symbol 6BH6-CME is set to download 'Pending'. | 2016-03-02 09:00:50 GCJ6-COMEX [CB] Daily #5 | Reloading chart. | 2016-03-02 09:00:50 HD Request # 17 | Receiving Intraday data for 6AH6-CME starting at 2016-03-02 08:59:52 | 2016-03-02 09:00:50 HD Request # 17 | Timestamp of first Intraday data file record written: 2016-03-02 08:59:56 | 2016-03-02 09:00:50 HD Request # 17 | Received 80 records from 2016-03-02 08:59:52 to 2016-03-02 09:00:30 (38.0 seconds) and wrote 72 records for 6AH6-CME | 2016-03-02 09:00:50 HD Request # 17 | Intraday download COMPLETE for 6AH6-CME. Completion time: 2s. Unique request ID: 16 | 2016-03-02 09:00:50 Removed historical data download ID 16 | 2016-03-02 09:00:50 Real-time Intraday chart data file updates started for 6AH6-CME | 2016-03-02 09:00:50 Opened cached Intraday file: C:\SierraChart\Data\6AH6-CME.scid | 2016-03-02 09:00:50 Intraday chart data file opened for 6AH6-CME | 2016-03-02 09:00:50 HD Request # 25 | Downloading Intraday chart data for CLJ6-NYMEX to the file CLJ6-NYMEX.scid. Service: rim | 2016-03-02 09:00:50 HD Request # 25 | Download start Date-Time: 2016-03-02 08:59:51.000 | 2016-03-02 09:00:50 HD Request # 25 | Sending historical data request. Start Date-Time: 2016-03-02 08:59:51. Record interval: 0. Symbol: CLJ6-NYMEX | 2016-03-02 09:00:50 Rithmic Trading | Message from server: Requesting historical Tick data. | 2016-03-02 09:00:50 Rithmic Trading | Starting real-time market data updates for: GCJ6-COMEX. ID: 10 | 2016-03-02 09:00:50 Intraday data recording state for symbol GCJ6-COMEX is set to download 'Pending'. | 2016-03-02 09:00:50 HD Request # 26 | Downloading Intraday chart data for GCJ6-COMEX to the file GCJ6-COMEX.scid. Service: comex | 2016-03-02 09:00:50 HD Request # 26 | Download start Date-Time: 2016-03-02 08:59:51.000 | 2016-03-02 09:00:50 HD Request # 26 | Error downloading historical Intraday data for GCJ6-COMEX. Not downloading Intraday data for symbol GCJ6-COMEX. Less than 10 minutes since last record Date-Time. | 2016-03-02 09:00:50 HD Request # 26 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for GCJ6-COMEX | 2016-03-02 09:00:50 HD Request # 26 | Intraday download COMPLETE for GCJ6-COMEX. Completion time: 0s. Unique request ID: 31 | 2016-03-02 09:00:50 Removed historical data download ID 31 | 2016-03-02 09:00:50 Real-time Intraday chart data file updates started for GCJ6-COMEX | 2016-03-02 09:00:50 Opened cached Intraday file: C:\SierraChart\Data\GCJ6-COMEX.scid | 2016-03-02 09:00:50 Intraday chart data file opened for GCJ6-COMEX | 2016-03-02 09:00:50 Rithmic Trading | Using primary service for historical data for GCJ6-COMEX | 2016-03-02 09:00:50 Intraday data recording state for symbol GCJ6-COMEX is set to download 'Pending'. | 2016-03-02 09:00:50 Rithmic Trading | Starting real-time market data updates for: 6NH6-CME. ID: 11 | 2016-03-02 09:00:50 Intraday data recording state for symbol 6NH6-CME is set to download 'Pending'. | 2016-03-02 09:00:50 HD Request # 27 | Downloading Intraday chart data for 6NH6-CME to the file 6NH6-CME.scid. Service: cme | 2016-03-02 09:00:50 HD Request # 27 | Download start Date-Time: 2016-03-02 08:59:52.000 | 2016-03-02 09:00:50 HD Request # 27 | Error downloading historical Intraday data for 6NH6-CME. Not downloading Intraday data for symbol 6NH6-CME. Less than 10 minutes since last record Date-Time. | 2016-03-02 09:00:50 HD Request # 27 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for 6NH6-CME | 2016-03-02 09:00:50 HD Request # 27 | Intraday download COMPLETE for 6NH6-CME. Completion time: 0s. Unique request ID: 33 | 2016-03-02 09:00:50 Removed historical data download ID 33 | 2016-03-02 09:00:50 Real-time Intraday chart data file updates started for 6NH6-CME | 2016-03-02 09:00:50 Opened cached Intraday file: C:\SierraChart\Data\6NH6-CME.scid | 2016-03-02 09:00:50 Intraday chart data file opened for 6NH6-CME | 2016-03-02 09:00:50 Rithmic Trading | Using primary service for historical data for 6NH6-CME | 2016-03-02 09:00:50 Intraday data recording state for symbol 6NH6-CME is set to download 'Pending'. | 2016-03-02 09:00:50 Rithmic Trading | Starting real-time market data updates for: 6SH6-CME. ID: 12 | 2016-03-02 09:00:50 Intraday data recording state for symbol 6SH6-CME is set to download 'Pending'. | 2016-03-02 09:00:50 HD Request # 28 | Downloading Intraday chart data for 6SH6-CME to the file 6SH6-CME.scid. Service: cme | 2016-03-02 09:00:50 HD Request # 28 | Download start Date-Time: 2016-03-02 08:59:09.000 | 2016-03-02 09:00:50 HD Request # 28 | Error downloading historical Intraday data for 6SH6-CME. Not downloading Intraday data for symbol 6SH6-CME. Less than 10 minutes since last record Date-Time. | 2016-03-02 09:00:50 HD Request # 28 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for 6SH6-CME | 2016-03-02 09:00:50 HD Request # 28 | Intraday download COMPLETE for 6SH6-CME. Completion time: 0s. Unique request ID: 35 | 2016-03-02 09:00:50 Removed historical data download ID 35 | 2016-03-02 09:00:50 Real-time Intraday chart data file updates started for 6SH6-CME | 2016-03-02 09:00:50 Opened cached Intraday file: C:\SierraChart\Data\6SH6-CME.scid | 2016-03-02 09:00:50 Intraday chart data file opened for 6SH6-CME | 2016-03-02 09:00:50 Rithmic Trading | Using primary service for historical data for 6SH6-CME | 2016-03-02 09:00:50 Intraday data recording state for symbol 6SH6-CME is set to download 'Pending'. | 2016-03-02 09:00:50 Rithmic Trading | Starting real-time market data updates for: ZBH6-CBOT. ID: 13 | 2016-03-02 09:00:50 Rithmic Trading | Starting real-time market data updates for: 6JH6-CME. ID: 14 | 2016-03-02 09:00:50 Intraday data recording state for symbol 6JH6-CME is set to download 'Pending'. | 2016-03-02 09:00:50 HD Request # 29 | Downloading Intraday chart data for 6JH6-CME to the file 6JH6-CME.scid. Service: cme | 2016-03-02 09:00:50 HD Request # 29 | Download start Date-Time: 2016-03-02 08:59:47.000 | 2016-03-02 09:00:50 HD Request # 29 | Error downloading historical Intraday data for 6JH6-CME. Not downloading Intraday data for symbol 6JH6-CME. Less than 10 minutes since last record Date-Time. | 2016-03-02 09:00:50 HD Request # 29 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for 6JH6-CME | 2016-03-02 09:00:50 HD Request # 29 | Intraday download COMPLETE for 6JH6-CME. Completion time: 0s. Unique request ID: 37 | 2016-03-02 09:00:50 Removed historical data download ID 37 | 2016-03-02 09:00:50 Real-time Intraday chart data file updates started for 6JH6-CME | 2016-03-02 09:00:50 Opened cached Intraday file: C:\SierraChart\Data\6JH6-CME.scid | 2016-03-02 09:00:50 Intraday chart data file opened for 6JH6-CME | 2016-03-02 09:00:50 Rithmic Trading | Using primary service for historical data for 6JH6-CME | 2016-03-02 09:00:50 Intraday data recording state for symbol 6JH6-CME is set to download 'Pending'. | 2016-03-02 09:00:50 6AH6-CME [CB] Daily #8 | Reloading chart. | 2016-03-02 09:00:50 HD Request # 25 | Receiving Intraday data for CLJ6-NYMEX starting at 2016-03-02 08:59:51 | 2016-03-02 09:00:50 HD Request # 25 | Timestamp of first Intraday data file record written: 2016-03-02 08:59:52 | 2016-03-02 09:00:50 HD Request # 25 | Received 1126 records from 2016-03-02 08:59:51 to 2016-03-02 09:00:52 (61.0 seconds) and wrote 1094 records for CLJ6-NYMEX | 2016-03-02 09:00:50 HD Request # 25 | Intraday download COMPLETE for CLJ6-NYMEX. Completion time: 0s. Unique request ID: 18 | 2016-03-02 09:00:50 Removed historical data download ID 18 | 2016-03-02 09:00:50 Real-time Intraday chart data file updates started for CLJ6-NYMEX | 2016-03-02 09:00:50 Opened cached Intraday file: C:\SierraChart\Data\CLJ6-NYMEX.scid | 2016-03-02 09:00:50 Intraday chart data file opened for CLJ6-NYMEX | 2016-03-02 09:00:50 HD Request # 30 | Downloading Intraday chart data for ESH6-CME to the file ESH6-CME.scid. Service: rim | 2016-03-02 09:00:50 HD Request # 30 | Download start Date-Time: 2016-03-02 08:59:51.000 | 2016-03-02 09:00:50 HD Request # 30 | Sending historical data request. Start Date-Time: 2016-03-02 08:59:51. Record interval: 0. Symbol: ESH6-CME | 2016-03-02 09:00:50 Rithmic Trading | Message from server: Requesting historical Tick data. | 2016-03-02 09:00:50 Rithmic Trading | Starting real-time market data updates for: DX FMH0016!-NYBOT. ID: 15 | 2016-03-02 09:00:50 Intraday data recording state for symbol DX FMH0016!-NYBOT is set to download 'Pending'. | 2016-03-02 09:00:50 HD Request # 31 | Downloading Intraday chart data for DX FMH0016!-NYBOT to the file DX FMH0016!-NYBOT.scid. Service: ice.us | 2016-03-02 09:00:50 HD Request # 31 | Download start Date-Time: 2016-03-02 08:59:26.000 | 2016-03-02 09:00:50 HD Request # 31 | Error downloading historical Intraday data for DX FMH0016!-NYBOT. Not downloading Intraday data for symbol DX FMH0016!-NYBOT. Less than 10 minutes since last record Date-Time. | 2016-03-02 09:00:50 HD Request # 31 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for DX FMH0016!-NYBOT | 2016-03-02 09:00:50 HD Request # 31 | Intraday download COMPLETE for DX FMH0016!-NYBOT. Completion time: 0s. Unique request ID: 39 | 2016-03-02 09:00:50 Removed historical data download ID 39 | 2016-03-02 09:00:50 Real-time Intraday chart data file updates started for DX FMH0016!-NYBOT | 2016-03-02 09:00:50 Opened cached Intraday file: C:\SierraChart\Data\DX FMH0016!-NYBOT.scid | 2016-03-02 09:00:50 Intraday chart data file opened for DX FMH0016!-NYBOT | 2016-03-02 09:00:50 Rithmic Trading | Using primary service for historical data for DX FMH0016!-NYBOT | 2016-03-02 09:00:50 Intraday data recording state for symbol DX FMH0016!-NYBOT is set to download 'Pending'. | 2016-03-02 09:00:50 6EH6-CME [CB] Daily #1 | Reloading chart. | 2016-03-02 09:00:50 HD Request # 30 | Receiving Intraday data for ESH6-CME starting at 2016-03-02 08:59:51 | 2016-03-02 09:00:50 HD Request # 30 | Timestamp of first Intraday data file record written: 2016-03-02 08:59:53 | 2016-03-02 09:00:50 HD Request # 30 | Received 1462 records from 2016-03-02 08:59:51 to 2016-03-02 09:00:52 (61.3 seconds) and wrote 1461 records for ESH6-CME | 2016-03-02 09:00:50 HD Request # 30 | Intraday download COMPLETE for ESH6-CME. Completion time: 0s. Unique request ID: 20 | 2016-03-02 09:00:50 Removed historical data download ID 20 | 2016-03-02 09:00:50 Real-time Intraday chart data file updates started for ESH6-CME | 2016-03-02 09:00:50 Opened cached Intraday file: C:\SierraChart\Data\ESH6-CME.scid | 2016-03-02 09:00:50 Intraday chart data file opened for ESH6-CME | 2016-03-02 09:00:50 HD Request # 32 | Downloading Intraday chart data for 6CH6-CME to the file 6CH6-CME.scid. Service: rim | 2016-03-02 09:00:50 HD Request # 32 | Download start Date-Time: 2016-03-02 08:59:41.000 | 2016-03-02 09:00:50 HD Request # 32 | Sending historical data request. Start Date-Time: 2016-03-02 08:59:41. Record interval: 0. Symbol: 6CH6-CME | 2016-03-02 09:00:50 Rithmic Trading | Message from server: Requesting historical Tick data. | 2016-03-02 09:00:50 Rithmic Trading | Starting real-time market data updates for: HGH6-COMEX. ID: 16 | 2016-03-02 09:00:50 6CH6-CME [CB] Daily #9 | Reloading chart. | 2016-03-02 09:00:53 HD Request # 32 | Receiving Intraday data for 6CH6-CME starting at 2016-03-02 08:59:41 | 2016-03-02 09:00:53 HD Request # 32 | Timestamp of first Intraday data file record written: 2016-03-02 08:59:53 | 2016-03-02 09:00:53 HD Request # 32 | Received 48 records from 2016-03-02 08:59:41 to 2016-03-02 09:00:52 (71.0 seconds) and wrote 44 records for 6CH6-CME | 2016-03-02 09:00:53 HD Request # 32 | Intraday download COMPLETE for 6CH6-CME. Completion time: 1s. Unique request ID: 22 | 2016-03-02 09:00:53 Removed historical data download ID 22 | 2016-03-02 09:00:53 Real-time Intraday chart data file updates started for 6CH6-CME | 2016-03-02 09:00:53 Opened cached Intraday file: C:\SierraChart\Data\6CH6-CME.scid | 2016-03-02 09:00:53 Intraday chart data file opened for 6CH6-CME | 2016-03-02 09:00:53 HD Request # 33 | Downloading Intraday chart data for 6EH6-CME to the file 6EH6-CME.scid. Service: rim | 2016-03-02 09:00:53 HD Request # 33 | Download start Date-Time: 2016-03-02 08:59:50.000 | 2016-03-02 09:00:53 HD Request # 33 | Sending historical data request. Start Date-Time: 2016-03-02 08:59:50. Record interval: 0. Symbol: 6EH6-CME | 2016-03-02 09:00:53 Rithmic Trading | Message from server: Requesting historical Tick data. | 2016-03-02 09:00:53 6BH6-CME [CB] Daily #6 | Reloading chart. | 2016-03-02 09:00:53 HD Request # 33 | Receiving Intraday data for 6EH6-CME starting at 2016-03-02 08:59:50 | 2016-03-02 09:00:53 HD Request # 33 | Timestamp of first Intraday data file record written: 2016-03-02 08:59:52 | 2016-03-02 09:00:53 HD Request # 33 | Received 138 records from 2016-03-02 08:59:50 to 2016-03-02 09:00:53 (63.0 seconds) and wrote 136 records for 6EH6-CME | 2016-03-02 09:00:53 HD Request # 33 | Intraday download COMPLETE for 6EH6-CME. Completion time: 0s. Unique request ID: 24 | 2016-03-02 09:00:53 Removed historical data download ID 24 | 2016-03-02 09:00:53 Real-time Intraday chart data file updates started for 6EH6-CME | 2016-03-02 09:00:53 Opened cached Intraday file: C:\SierraChart\Data\6EH6-CME.scid | 2016-03-02 09:00:53 Intraday chart data file opened for 6EH6-CME | 2016-03-02 09:00:53 HD Request # 34 | Downloading Intraday chart data for HGK6-COMEX to the file HGK6-COMEX.scid. Service: rim | 2016-03-02 09:00:53 HD Request # 34 | Download start Date-Time: 2016-03-02 08:59:45.000 | 2016-03-02 09:00:53 HD Request # 34 | Sending historical data request. Start Date-Time: 2016-03-02 08:59:45. Record interval: 0. Symbol: HGK6-COMEX | 2016-03-02 09:00:53 Rithmic Trading | Message from server: Requesting historical Tick data. | 2016-03-02 09:00:53 GCJ6-COMEX [CB] Daily #5 | Reloading chart. | 2016-03-02 09:00:53 HD Request # 34 | Receiving Intraday data for HGK6-COMEX starting at 2016-03-02 08:59:45 | 2016-03-02 09:00:53 HD Request # 34 | Timestamp of first Intraday data file record written: 2016-03-02 08:59:55 | 2016-03-02 09:00:53 HD Request # 34 | Received 50 records from 2016-03-02 08:59:45 to 2016-03-02 09:00:54 (69.0 seconds) and wrote 47 records for HGK6-COMEX | 2016-03-02 09:00:53 HD Request # 34 | Intraday download COMPLETE for HGK6-COMEX. Completion time: 1s. Unique request ID: 26 | 2016-03-02 09:00:53 Removed historical data download ID 26 | 2016-03-02 09:00:53 Real-time Intraday chart data file updates started for HGK6-COMEX | 2016-03-02 09:00:53 Opened cached Intraday file: C:\SierraChart\Data\HGK6-COMEX.scid | 2016-03-02 09:00:53 Intraday chart data file opened for HGK6-COMEX | 2016-03-02 09:00:53 HD Request # 35 | Downloading Intraday chart data for ZBM6-CBOT to the file ZBM6-CBOT.scid. Service: rim | 2016-03-02 09:00:53 HD Request # 35 | Download start Date-Time: 2016-03-02 08:59:40.000 | 2016-03-02 09:00:53 HD Request # 35 | Sending historical data request. Start Date-Time: 2016-03-02 08:59:40. Record interval: 0. Symbol: ZBM6-CBOT | 2016-03-02 09:00:53 Rithmic Trading | Message from server: Requesting historical Tick data. | 2016-03-02 09:00:53 ESH6-CME [CB] Daily #4 | Reloading chart. | 2016-03-02 09:00:53 HD Request # 35 | Receiving Intraday data for ZBM6-CBOT starting at 2016-03-02 08:59:40 | 2016-03-02 09:00:53 HD Request # 35 | Timestamp of first Intraday data file record written: 2016-03-02 08:59:53 | 2016-03-02 09:00:53 HD Request # 35 | Received 256 records from 2016-03-02 08:59:40 to 2016-03-02 09:00:54 (74.0 seconds) and wrote 255 records for ZBM6-CBOT | 2016-03-02 09:00:53 HD Request # 35 | Intraday download COMPLETE for ZBM6-CBOT. Completion time: 0s. Unique request ID: 28 | 2016-03-02 09:00:53 Removed historical data download ID 28 | 2016-03-02 09:00:53 Real-time Intraday chart data file updates started for ZBM6-CBOT | 2016-03-02 09:00:53 Opened cached Intraday file: C:\SierraChart\Data\ZBM6-CBOT.scid | 2016-03-02 09:00:53 Intraday chart data file opened for ZBM6-CBOT | 2016-03-02 09:00:53 HD Request # 36 | Downloading Intraday chart data for 6BH6-CME to the file 6BH6-CME.scid. Service: rim | 2016-03-02 09:00:53 HD Request # 36 | Download start Date-Time: 2016-03-02 08:59:50.000 | 2016-03-02 09:00:53 HD Request # 36 | Sending historical data request. Start Date-Time: 2016-03-02 08:59:50. Record interval: 0. Symbol: 6BH6-CME | 2016-03-02 09:00:53 Rithmic Trading | Message from server: Requesting historical Tick data. | 2016-03-02 09:00:53 ZBH6-CBOT [CB] Daily #7 | Reloading chart. | 2016-03-02 09:00:53 HD Request # 36 | Receiving Intraday data for 6BH6-CME starting at 2016-03-02 08:59:50 | 2016-03-02 09:00:53 HD Request # 36 | Timestamp of first Intraday data file record written: 2016-03-02 08:59:58 | 2016-03-02 09:00:53 HD Request # 36 | Received 75 records from 2016-03-02 08:59:50 to 2016-03-02 09:00:54 (64.0 seconds) and wrote 73 records for 6BH6-CME | 2016-03-02 09:00:53 HD Request # 36 | Intraday download COMPLETE for 6BH6-CME. Completion time: 0s. Unique request ID: 30 | 2016-03-02 09:00:53 Removed historical data download ID 30 | 2016-03-02 09:00:53 Real-time Intraday chart data file updates started for 6BH6-CME | 2016-03-02 09:00:53 Opened cached Intraday file: C:\SierraChart\Data\6BH6-CME.scid | 2016-03-02 09:00:53 Intraday chart data file opened for 6BH6-CME | 2016-03-02 09:00:53 HD Request # 37 | Downloading Intraday chart data for GCJ6-COMEX to the file GCJ6-COMEX.scid. Service: rim | 2016-03-02 09:00:53 HD Request # 37 | Download start Date-Time: 2016-03-02 08:59:51.000 | 2016-03-02 09:00:53 HD Request # 37 | Sending historical data request. Start Date-Time: 2016-03-02 08:59:51. Record interval: 0. Symbol: GCJ6-COMEX | 2016-03-02 09:00:53 Rithmic Trading | Message from server: Requesting historical Tick data. | 2016-03-02 09:00:53 6BH6-CME [CB] Daily #6 | Reloading chart. | 2016-03-02 09:00:55 HD Request # 37 | Receiving Intraday data for GCJ6-COMEX starting at 2016-03-02 08:59:51 | 2016-03-02 09:00:55 HD Request # 37 | Timestamp of first Intraday data file record written: 2016-03-02 08:59:53 | 2016-03-02 09:00:55 HD Request # 37 | Received 179 records from 2016-03-02 08:59:51 to 2016-03-02 09:00:55 (64.0 seconds) and wrote 178 records for GCJ6-COMEX | 2016-03-02 09:00:55 HD Request # 37 | Intraday download COMPLETE for GCJ6-COMEX. Completion time: 0s. Unique request ID: 32 | 2016-03-02 09:00:55 Removed historical data download ID 32 | 2016-03-02 09:00:55 Real-time Intraday chart data file updates started for GCJ6-COMEX | 2016-03-02 09:00:55 Opened cached Intraday file: C:\SierraChart\Data\GCJ6-COMEX.scid | 2016-03-02 09:00:55 Intraday chart data file opened for GCJ6-COMEX | 2016-03-02 09:00:55 HD Request # 38 | Downloading Intraday chart data for 6NH6-CME to the file 6NH6-CME.scid. Service: rim | 2016-03-02 09:00:55 HD Request # 38 | Download start Date-Time: 2016-03-02 08:59:52.000 | 2016-03-02 09:00:55 HD Request # 38 | Sending historical data request. Start Date-Time: 2016-03-02 08:59:52. Record interval: 0. Symbol: 6NH6-CME | 2016-03-02 09:00:55 Rithmic Trading | Message from server: Requesting historical Tick data. | 2016-03-02 09:00:55 HD Request # 38 | Receiving Intraday data for 6NH6-CME starting at 2016-03-02 08:59:52 | 2016-03-02 09:00:56 HD Request # 38 | Timestamp of first Intraday data file record written: 2016-03-02 09:00:15 | 2016-03-02 09:00:56 HD Request # 38 | Received 9 records from 2016-03-02 08:59:52 to 2016-03-02 09:00:54 (62.0 seconds) and wrote 4 records for 6NH6-CME | 2016-03-02 09:00:56 HD Request # 38 | Intraday download COMPLETE for 6NH6-CME. Completion time: 0s. Unique request ID: 34 | 2016-03-02 09:00:56 Removed historical data download ID 34 | 2016-03-02 09:00:56 Real-time Intraday chart data file updates started for 6NH6-CME | 2016-03-02 09:00:56 Opened cached Intraday file: C:\SierraChart\Data\6NH6-CME.scid | 2016-03-02 09:00:56 Intraday chart data file opened for 6NH6-CME | 2016-03-02 09:00:56 HD Request # 39 | Downloading Intraday chart data for 6SH6-CME to the file 6SH6-CME.scid. Service: rim | 2016-03-02 09:00:56 HD Request # 39 | Download start Date-Time: 2016-03-02 08:59:09.000 | 2016-03-02 09:00:56 HD Request # 39 | Sending historical data request. Start Date-Time: 2016-03-02 08:59:09. Record interval: 0. Symbol: 6SH6-CME | 2016-03-02 09:00:56 Rithmic Trading | Message from server: Requesting historical Tick data. | 2016-03-02 09:00:56 HD Request # 39 | Receiving Intraday data for 6SH6-CME starting at 2016-03-02 08:59:09 | 2016-03-02 09:00:56 HD Request # 39 | Timestamp of first Intraday data file record written: 2016-03-02 09:00:02 | 2016-03-02 09:00:56 HD Request # 39 | Received 10 records from 2016-03-02 08:59:09 to 2016-03-02 09:00:52 (103.0 seconds) and wrote 9 records for 6SH6-CME | 2016-03-02 09:00:56 HD Request # 39 | Intraday download COMPLETE for 6SH6-CME. Completion time: 1s. Unique request ID: 36 | 2016-03-02 09:00:56 Removed historical data download ID 36 | 2016-03-02 09:00:56 Real-time Intraday chart data file updates started for 6SH6-CME | 2016-03-02 09:00:56 Opened cached Intraday file: C:\SierraChart\Data\6SH6-CME.scid | 2016-03-02 09:00:56 Intraday chart data file opened for 6SH6-CME | 2016-03-02 09:00:56 HD Request # 40 | Downloading Intraday chart data for 6JH6-CME to the file 6JH6-CME.scid. Service: rim | 2016-03-02 09:00:56 HD Request # 40 | Download start Date-Time: 2016-03-02 08:59:47.000 | 2016-03-02 09:00:56 HD Request # 40 | Sending historical data request. Start Date-Time: 2016-03-02 08:59:47. Record interval: 0. Symbol: 6JH6-CME | 2016-03-02 09:00:56 Rithmic Trading | Message from server: Requesting historical Tick data. | 2016-03-02 09:00:56 HD Request # 40 | Receiving Intraday data for 6JH6-CME starting at 2016-03-02 08:59:47 | 2016-03-02 09:00:56 HD Request # 40 | Timestamp of first Intraday data file record written: 2016-03-02 08:59:53 | 2016-03-02 09:00:56 HD Request # 40 | Received 92 records from 2016-03-02 08:59:47 to 2016-03-02 09:00:54 (67.0 seconds) and wrote 85 records for 6JH6-CME | 2016-03-02 09:00:56 HD Request # 40 | Intraday download COMPLETE for 6JH6-CME. Completion time: 0s. Unique request ID: 38 | 2016-03-02 09:00:56 Removed historical data download ID 38 | 2016-03-02 09:00:56 Real-time Intraday chart data file updates started for 6JH6-CME | 2016-03-02 09:00:56 Opened cached Intraday file: C:\SierraChart\Data\6JH6-CME.scid | 2016-03-02 09:00:56 Intraday chart data file opened for 6JH6-CME | 2016-03-02 09:00:56 HD Request # 41 | Downloading Intraday chart data for DX FMH0016!-NYBOT to the file DX FMH0016!-NYBOT.scid. Service: rim | 2016-03-02 09:00:56 HD Request # 41 | Download start Date-Time: 2016-03-02 08:59:26.000 | 2016-03-02 09:00:56 HD Request # 41 | Sending historical data request. Start Date-Time: 2016-03-02 08:59:26. Record interval: 0. Symbol: DX FMH0016!-NYBOT | 2016-03-02 09:00:56 Rithmic Trading | Message from server: Requesting historical Minute data. | 2016-03-02 09:00:56 HD Request # 41 | Receiving Intraday data for DX FMH0016!-NYBOT starting at 2016-03-02 08:58:00 | 2016-03-02 09:00:56 HD Request # 41 | Received 3 records from 2016-03-02 08:58:00 to 2016-03-02 08:59:00 (60.0 seconds) and wrote 0 records for DX FMH0016!-NYBOT | 2016-03-02 09:00:56 HD Request # 41 | Intraday download COMPLETE for DX FMH0016!-NYBOT. Completion time: 0s. Unique request ID: 40 | 2016-03-02 09:00:56 Removed historical data download ID 40 | 2016-03-02 09:00:56 Real-time Intraday chart data file updates started for DX FMH0016!-NYBOT | 2016-03-02 09:00:56 Opened cached Intraday file: C:\SierraChart\Data\DX FMH0016!-NYBOT.scid | 2016-03-02 09:00:56 Intraday chart data file opened for DX FMH0016!-NYBOT | 2016-03-02 09:00:56 Error opening study collection file: C:\SierraChart\Data\DVP .StdyCollct. Windows error code 2: The system cannot find the file specified. | 2016-03-02 09:01:36 * ESH6-CME [CB] Daily #4 | Reloading chart. | 2016-03-02 09:01:36 HTTP connection to ds01.ddfplus.com:80 (4) | Closed. No error. | 2016-03-02 09:01:54 HTTP connection to ds01.ddfplus.com:80 (4) | Shutdown and closed. | 2016-03-02 09:01:54 HGH6-COMEX [CB] Daily #3 | Reloading chart. | 2016-03-02 09:03:51 Error opening study collection file: C:\SierraChart\Data\DVP .StdyCollct. Windows error code 2: The system cannot find the file specified. | 2016-03-02 09:04:04 * |
[2016-03-02 14:53:26] |
Select Global Settings >> Tool Configs >> Draw Volume Profile. Clear the Study Collection Name setting. Check all of the Tool Configurations (TC#) 1 through 8. Press OK. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-03-02 14:53:48
