Date/Time: Fri, 27 Dec 2024 02:11:56 +0000
Charts automatically scroll right
View Count: 2213
[2016-03-01 15:26:44] |
User609105 - Posts: 28 |
I seemed to have unchecked the box that means that a chart will automatically show the latest price - ie it is scrolled to the right. At the moment I have to manually scroll right sometimes. Could someone point me in the right direction? Thanks |
[2016-03-01 17:39:38] |
Refer to the documentation here about this: https://www.sierrachart.com/index.php?page=doc/doc_WorkingWithCharts.html#AutomaticScrolling Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-03-01 17:44:00
[2016-03-01 17:44:11] |
The prior post has been updated. This is the relevant documentation on this subject: https://www.sierrachart.com/index.php?page=doc/doc_WorkingWithCharts.html#AutomaticScrolling Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-03-01 17:44:22
[2016-03-02 12:13:37] |
Simple - thanks
