Date/Time: Fri, 27 Dec 2024 02:25:27 +0000
Auto Retracement/Projection
View Count: 721
[2016-03-01 14:32:05] |
User937866 - Posts: 12 |
Is there a way to set the Auto Retracement/Projection study to cover a certain time period. For example, can I set it to start at 9am when the Oil Pit opens and run until 2:30pm when it closes?
[2016-03-01 18:33:02] |
Only through adjusting the Session Times for the chart: https://www.sierrachart.com/index.php?page=doc/doc_SessionTimes.php Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-03-01 19:02:35] |
I did try that but I have the Daily OHLC Study on my chart as well and when I switch to 9:00am to 2:30pm it doesn't give me the full previous days' High and Low. It uses that time period. Can I have it give me the full 24hr OHLC numbers with a chart set for session time?
[2016-03-01 19:10:42] |
In this case you will need to set the Session times to span the full 24 hours. However there is another method to accomplish what you want and that is documented here: https://www.sierrachart.com/index.php?page=doc/doc_StudyPriceOverlayStudy.php#OverlayStudyDiffSessionTimes Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-03-01 19:11:05
