Date/Time: Mon, 21 Sep 2026 14:51:18 +0000
replay - prob with Trade Activity Log
View Count: 885
| [2016-03-01 05:30:56] |
| amue - Posts: 8 |
Hi all, I've got a problem with the Trade Activity Log while simulating/replaying one of the last days of the current CL future: - I am using the "MovAvg simple" example from the online docs - the intraday data is loaded correctly - I can see the order fills in the chart (they seem to be correct) -> the simulation in itself seems to be ok - but the Trade Activity Log shows no trades (only the "Trade Stats for Charts" shows some data) - the header of the Log shows "All Activity", "Simulated", "[Sim]CL-201604-NYMEX", "Sim1", "Long & Short" |
| [2016-03-01 05:39:56] |
Make sure the Symbol, Trade Account and Date Range are set correctly at the top of the Trade Activity Log. Only you know what those should be set to. We do not. Some setting is not correct. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-03-01 05:40:18
