Date/Time: Fri, 27 Dec 2024 15:46:09 +0000
Missing data on intraday VIX chart
View Count: 1068
[2016-02-29 21:27:48]
User787032 - Posts: 37
I use the CQG FIX data service via my broker, AMP Futures. Recently I subscribed to the VIX intraday data feed. I've noticed that on my Sierra Chart platform I'm missing some entries for the VIX intraday data. For example, on a 1 minute chart of the VXJ16 futures contract, although most of the bars are at 1 minute intervals, quite often there will be a gap of 2 or 3 minutes, or very occasionally, 5 or more minutes between bars.
I checked with support at AMP Futures and CQG and they suggested I contact you for any information regarding problems with this data feed.
Can you let me know if this is a known problem with VIX futures contracts, and/or if there is a solution that I can apply to fix it?
[2016-03-01 04:44:24]
We are working on this. Just give us about one day.
[2016-03-08 00:23:37]
Blue Brazilian - Posts: 42
Any progress on this?
[2016-03-08 04:00:10]
AMP needs to enable the exchange for us, for us to be able to maintain historical data. We have not yet heard back from them on this. We contacted them again.
We have added some historical data. If you re-download the data in the chart you will get it now. Select Edit >>Delete All Data and Download.
[2016-03-09 20:30:31]
I contacted AMP Support today and they say that the exchange is already enabled. Can you check this again please?
Thanks.
[2016-03-09 20:54:59]
This is all done and ready.
Update Sierra Chart following the instructions here:
https://www.sierrachart.com/index.php?page=doc/download.php#FastUpdate
Update the Symbol Settings:
https://www.sierrachart.com/index.php?page=doc/doc_GlobalSymbolSettings.php#UpdateSettings
Go to the chart and re-download the data with Edit >>Delete All Data and Download.
Date Time Of Last Edit: 2016-03-09 20:55:17
[2016-03-09 23:49:45]
Looks good now.
Thanks for your help.
[2016-03-09 23:58:34]
OK good.
