Date/Time: Fri, 27 Dec 2024 01:37:16 +0000
Commission is not calculated in the report
View Count: 1115
[2016-02-29 19:18:30] |
User269983 - Posts: 31 |
Please see attached. I set up round trip commission for ES at $3.68 but it is not being deducted from the P/L. |
sc-no-comm.png / V - Attached On 2016-02-29 19:17:40 UTC - Size: 90.28 KB - 243 views |
[2016-02-29 21:41:30] |
Just want to add, click "use commission" did not change the report. In additional, there is no data for "Trade Statistics", Trades, "Period Trade Stats" |
sc-no-comm1.png / V - Attached On 2016-02-29 21:41:24 UTC - Size: 32.05 KB - 239 views |
[2016-03-01 02:03:08] |
Refer to the documentation for the Round turn Commission setting here: http://www.sierrachart.com/index.php?page=doc/doc_GlobalSymbolSettings.php#SymbolSettingsControls Refer to the documentation here for "Trade Statistics", Trades, "Period Trade Stats": http://www.sierrachart.com/index.php?page=doc/doc_TradeActivityLog.php#TradeStatisticsTab You must follow the instructions to properly use those tabs. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-03-01 02:04:17
