Date/Time: Fri, 27 Dec 2024 02:42:22 +0000
Which IDE do you recommend/
View Count: 895
[2016-02-29 18:41:50] |
Adam - Posts: 141 |
I noticed that VS 2010 C++ Express is now gone from the MSFT site. I have downloaded the VS 2015 community edition (which shocked me at being 13gb!) is that the right one? Also you note to copy and paste the code in the image below, but do you have this in a format that can be copied as i can only see it in JPG format. Thanks Adam |
cbcbvcbgfdfg.JPG / V - Attached On 2016-02-29 18:41:37 UTC - Size: 88.92 KB - 315 views Attachment Deleted. |
[2016-02-29 19:37:40] |
The Community Edition sounds like it should be fine. The documentation has been corrected to include actual text which can be copied. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-02-29 19:38:29] |
Adam - Posts: 141 |
Cheers guys
