Date/Time: Fri, 27 Dec 2024 02:24:51 +0000
Message Log
View Count: 625
[2016-02-29 13:21:21] |
User40725 - Posts: 5 |
Just this past weekend I started getting a Message Log every time I use the DVP (Draw Volume Profile) Tool. Had never gotten it before and Sent For Analysis was clicked and it then directed me here to the support board. It is a nuisance to have to close this every time I use the tool which I do a lot. Thanks |
[2016-02-29 18:50:57] |
Provide us the specific line in the Message Log that you see. Select it and press the Copy Selection button at the top of the Message Log window and paste it here.
