Date/Time: Fri, 27 Dec 2024 02:04:34 +0000
More configs per tool
View Count: 711
[2016-02-29 10:27:34] |
User37537 - Posts: 78 |
Hi support, Is there any way to have more than 8 custom configs for a given tool? For common tools, such as text and extending rectangles, I have run out since I use different colors for different timeframes and to mean different things. A user-adjustable global maximum would be useful, or at the very least a larger hard-coded maximum, say 20 or so, would be really great. |
[2016-02-29 13:00:58] |
Marek F - Posts: 244 |
+1 ! It would be very useful to increase the number of the Tool Config, although up to 15-20. |
[2016-02-29 18:53:24] |
This is very difficult to support. But will be considered much later on.
[2016-02-29 19:03:06] |
For text, there are the Custom Text Drawing Control Bar Buttons: https://www.sierrachart.com/index.php?page=doc/doc_Tools.html#CustomTextDrawingControlBarButtons Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-02-29 19:03:21
