Date/Time: Fri, 27 Dec 2024 01:44:54 +0000
Numbers bar
View Count: 827
[2016-02-29 09:59:36] |
User738785 - Posts: 4 |
Hello I want to show numbers bar study on data from IB. If i add the study, chart not show. Need i have Package 5? Thank you. |
[2016-02-29 17:20:43] |
You will require Sierra Chart service package 5 and you will require the Sierra Chart Exchange Data Feed: Sierra Chart Exchange Data Feed Both of these are needed. Not one or the other but both. To change your Sierra Chart service package, select "Help >> Account Control Panel" on the Sierra Chart program menu. On the displayed webpage, click on "Change Service Package".
The remaining service usage time on your account will be adjusted based upon the cost of the package you are changing to. If the new package is a higher-priced package, then the usage time will be reduced due to the higher price. There is no charge for changing your Sierra Chart service package. Only your Sierra Chart account usage time ending date is adjusted. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-02-29 17:21:18
[2016-03-01 17:30:09] |
thank you
