Date/Time: Tue, 06 Oct 2026 02:54:46 +0000
Multiple stops with one target.
View Count: 1971
| [2016-02-28 19:07:07] |
| Mike_S - Posts: 42 |
I can't figure this out even with all the documentation and am about to pull my hair out. I want to buy 1 contract with a target of 11 ticks. (easy) Once i get to 7 ticks, I want to lock in 1. 8 ticks, lock 2 9 ticks, lock 6 10 ticks lock 8 The first 2 i can easily get with "Move to breakeven for stop" (step 1 and 2). When I try to get the others is where I get thrown off. A step 3, and 4 would have made it nice and easy. I won't go through the huge list of things i've tried. Thank you Date Time Of Last Edit: 2016-02-28 19:29:25
| [2016-02-28 19:22:04] |
Not totally clear what you want to do, but if you need 4 steps for the Move to Breakeven functionality, then that is not supported. There are only two of them.
| [2016-02-28 19:24:39] |
I want to tighten my stop by a greater amount each time as I get closer to my target. Profit of 7 ticks, I want to lock in 1. profit 8 ticks, lock 2 9 ticks, lock 6 10 ticks lock 8 Date Time Of Last Edit: 2016-02-28 19:25:27
| [2016-02-28 23:10:39] |
OK, this is not supported unless you do this through your own custom study using ACSIL trading: http://www.sierrachart.com/index.php?page=doc/doc_ACSILTrading.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
