Date/Time: Fri, 27 Dec 2024 02:18:59 +0000
[User Discussion] - Turn off current forming candle
View Count: 825
[2016-02-28 16:33:27]
User711279 - Posts: 4
Hi I'm using 1 minute candles with transact. Obviously the current candle flickers (fills up and down) and moves as it forms. IS there a way to suspend or hide the current forming candle. I would like to view the candle after it has formed.
Thanks.
[2016-02-28 18:26:00]
Sawtooth - Posts: 4143
You can do it with the Spreadsheet Study study.
Put the attached in your Sierra Chart \Data folder, go the Analysis >> Current candle blank.
Limitation: it will only display historical candles equal to the Number of Rows setting in the spreadsheet study settings.
attachmentCurrent candle blank.scss - Attached On 2016-02-28 18:25:06 UTC - Size: 42.03 KB - 350 views
attachmentCurrent candle blank-.StdyCollct - Attached On 2016-02-28 18:25:18 UTC - Size: 9.4 KB - 324 views
[2016-02-28 20:26:09]
Just to be clear, while live trading or simulation trading, the current candle formation can not be turned off? Correct? Thanks
[2016-02-28 22:57:05]
Yes that is correct but the user has provided a Spreadsheet Study to accomplish this.
