Date/Time: Fri, 27 Dec 2024 02:05:02 +0000
Chart >> Chart Settings >> Automatically Rollover Futures Symbol
View Count: 958
[2016-02-28 06:44:38]
pkhst958 - Posts: 57
Hi all,
the "Chart >> Chart Settings >> Automatically Rollover Futures Symbol" works only for me if I close sc and open it again.
Should it be working, if I just keep running sc?
[2016-02-28 09:31:06]
If a chart is not reloaded the rollover will not occur automatically. To force a rollover you can use Chart >> Reload and Recalculate.
Date Time Of Last Edit: 2016-02-28 09:31:53
