Date/Time: Tue, 04 Nov 2025 18:08:35 +0000
New User platform info
View Count: 3189
| [2013-03-28 15:38:57] |
| User23815 - Posts: 211 |
I just started using SC last week. After using TradeStation, Ninja and Ensign, I am very pleased so far. I wish I had found SC sooner. It appears SC is a Windows based platform. Is that correct? I know others have switched but I like the SC environment. For my knowledge staying with SC, are there plans to change the platform or other major changes in the works? Is there a place where I can see testimonials? Thanks |
| [2013-03-28 21:12:54] |
Yes, Sierra Chart is designed for Windows. Many improvements to Sierra Chart will be made. We do plan to support other operating systems. Refer to this page: https://www.sierrachart.com/index.php?l=doc/AboutUs.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2013-03-28 21:30:53] |
| [2013-03-28 21:34:44] |
Thanks for the reply. Yes, I reviewed the About us page today. I just wanted to make sure that you weren't on the brink of moving to another platform or anything that would drastically change your current platform. While there are many features that I haven't yet explored, so far SC seems to fit my needs very well with room to focus and simplify my trading. I'm hopeful that I have found a new home for my software needs.
| [2013-03-28 21:57:52] |
No, there will not be drastic changes. Only incremental improvements and new features.
