Date/Time: Sat, 03 Oct 2026 07:15:57 +0000
AMP disappeared from list of supported data services in documentation
View Count: 1062
| [2016-02-27 18:03:49] |
| User13668 - Posts: 296 |
Any reason why they seem to have been removed from this list? https://www.sierrachart.com/index.php?page=doc/Data.php#Services |
| [2016-02-27 18:09:10] |
That page does not list brokers necessarily but Data services or Trading platform services or Trading services that provide their own trading technology. AMP themselves is not a trading technology provider so they will not be listed. If you want to connect to Trading Technologies FIX or AMP/TTNet follow the instructions here: https://www.sierrachart.com/index.php?page=doc/TradingTechnologies.php We made an update to the page making reference to AMP/TTNet. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-02-27 18:09:37
| [2016-02-27 18:25:24] |
Okay, I understand the subtlety and your logic. But without picking on anyone, why is Optimus Trading Group included in that list then? As far as I am aware they are an introducing broker (in fact for AMP as one example) and do not provide their own data feed or technology. Their inclusion created my confusion because I thought Optimus is there so where is AMP. |
| [2016-02-27 19:02:14] |
Optimus was supposed to have been removed from that page but there was a misunderstanding with that task and it has been removed now.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-02-27 19:02:25
