Date/Time: Fri, 27 Dec 2024 17:53:06 +0000
Hi/Lo for the Time Period - Unstable
View Count: 745
[2016-02-26 21:05:48] |
AP - Posts: 117 |
Hi - I tried this multiple times and it just will not display; in fact it did not work at all. In trying to use this above mentioned study for say Stochastics (i.e. %K) to get the high / low of the day - it just does not work. I also tried using study reference absolute values of %K and then applied the above study and it still did not populate. Please - is there a way to work this? |
[2016-02-26 22:04:57] |
No, this study is designed only to work with the main price graph of the chart. It cannot be based on other studies.
