Date/Time: Wed, 30 Oct 2024 22:55:53 +0000
Numbers Bars coloring zeros
View Count: 1511
[2013-07-01 15:47:24]
user727 - Posts: 16
Using the new Numbers Bars study; really like the Ask/Bid Vol Split background.
I would like to turn off the numbers and see only the background, but also need to see zeros.
Problem is background is coloring the zero side as if it is >0 (when price level value is not zero zero) so background only does not show zeros--see pic of chart--why isn't a zero always the dark brown color that zero zero is?
I've fiddled with the settings trying to achieve this but can't (included pics of settings).
Is there a setting combination that achieves this? If not, seems coding should be modified--seems to me a zero should always show as zero in the background.
Thanks!
Date Time Of Last Edit: 2013-07-01 15:50:42
imageChart.jpg / V - Attached On 2013-07-01 15:47:02 UTC - Size: 408.27 KB - 532 views
imageSettings 1.jpg / V - Attached On 2013-07-01 15:47:09 UTC - Size: 398.96 KB - 498 views
imageSettings 2.jpg / V - Attached On 2013-07-01 15:47:17 UTC - Size: 378.97 KB - 493 views
