Date/Time: Fri, 18 Sep 2026 12:26:45 +0000
Can you please explain
View Count: 1014
| [2016-02-26 19:18:17] |
| R1sk - Posts: 259 |
You closed my support request little a bit too early. Please I need a bit more explanation. What I did wrong if I found a bug from your application and then reported it to you by giving a simple and clear example ? I am talking about this request: How to see is the user drawing 'selected' or not ? Or is it really so that the sc.ActiveToolIndex is working properly and the mistake is me ? |
| [2016-02-26 20:06:52] |
We will be responding in that thread to this question.
| [2016-02-26 21:07:48] |
| R1sk - Posts: 259 |
I definitely understand that it is not in the scope of your support to teach me how to implement things by the "Sierra Chart way" so could you please direct me to some forum you think is the best place to ask this kind of questions ? I hope I did not do any harm for you with my questions. Thanks |
| [2016-02-26 22:28:25] |
We are opening the thread and will be posting in there.
