Date/Time: Fri, 27 Dec 2024 18:53:04 +0000
Trade Window Default
View Count: 675
[2016-02-26 17:44:09] |
markuz - Posts: 90 |
Is there any way to default "support scale in" as always being checked from the Trade window under the "m" button?
support_scale_in_default.png / V - Attached On 2016-02-26 17:44:06 UTC - Size: 44.3 KB - 297 views |
[2016-02-26 19:23:48] |
Refer to: https://www.sierrachart.com/index.php?page=doc/doc_TradeWindow.html#SavingConfiguration Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
