Date/Time: Mon, 28 Sep 2026 04:42:46 +0000
Sheets (change tabs, alias?)
View Count: 1350
| [2016-02-26 10:34:47] |
| phaedonk - Posts: 352 |
1) Is there a way to quickly jump between tabs, instead of going through the drop down list? That is tedious when you have many sheets in one spreadsheet. 2) Is there a way to implement an alias to sheet names? I understand that I cannot change their name and still get updates now. Again, I am constantly switching between sheets to find the one I'm looking for. 3) FYI, when a SS is detached the option to Find and Insert symbol does not work. Thank you. |
| [2016-02-26 18:20:51] |
1, 2. We will see about these. 3. We will solve this. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2016-02-27 16:15:24] |
That would be great. Also, the Undo button. I gather it can only undo/redo tha last action? Can this be more like Excel (ie more undos remembered etc)? I inadvertently changed a bunch of stuff once and had to redo a lot of formulas.
| [2016-04-12 08:14:02] |
Any info on this, especially 2?
| [2016-04-25 16:15:29] |
An answer here please?
| [2016-04-25 17:41:45] |
You can rename a Sheet through the Spreadsheet menu. If you are referring to renaming a Sheet in a spreadsheet used by the Spreadsheet studies, then this capability is coming. Not sure when though. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
