Date/Time: Fri, 27 Dec 2024 18:35:22 +0000
SMS
View Count: 756
[2016-02-26 09:52:11] |
Ziklag - Posts: 73 |
Hi, I've upgraded to Sierra Service-Level-5 specifically for purposes of getting SMS Alerts each time a trade is entered. How do I configure this; I've tried to read around but its a bit confusing, thanks.
[2016-02-26 15:31:18] |
Sierra Chart - Max - Posts: 5770 |
You will need to enable SMS Alerts for your account here: https://www.sierrachart.com/usercp.php?page=SMS And under General Settings within Sierra Chart, you will also need to enable SMS Alerts and add your cellphone number for the Alerts that you want to trigger a SMS: https://www.sierrachart.com/index.php?page=doc/doc_GeneralSettings.html#AlertSoundSettings Sierra Chart Support Date Time Of Last Edit: 2016-02-26 18:32:16
[2016-02-26 18:34:39] |
SMS works with all Service Packages. You do not require service package 5 for that, so we can change your service package back to what you had before.
