Date/Time: Fri, 27 Dec 2024 17:53:19 +0000
Alarms triggered by "always visible" windows
View Count: 639
[2016-02-26 01:03:41] |
Willson - Posts: 176 |
If alarm is triggered on a window native to an ES chartbook, and the window is marked "Always visible" will it trigger when I have switched to an NQ chartbook? for example? Regards |
[2016-02-26 04:02:43] |
Yes. Alert Condition evaluation is not affected by whether a chart is visible or not.
