Date/Time: Fri, 27 Dec 2024 18:25:28 +0000
Time and Sales some bug
View Count: 717
[2016-02-26 00:49:32] |
GPST10 - Posts: 139 |
Time and sales window behaving strange, after opening SETTINGS in T&S and after making changes I pressed OK but SETTINGS window stays open and changes are all not taking effect or some taking very slowly over time/ restart but after pressing OK window should be gone but it is not, can you confirm?
[2016-02-26 03:51:17] |
We are aware of a problem where the Time and Sales Settings window does not close when pressing OK. The changes do take effect but you need to press Cancel after pressing OK, to close it. We are going to have a new release out today. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
