Date/Time: Sun, 13 Sep 2026 02:20:55 +0000
Bar start and end time
View Count: 1602
[2016-02-25 23:13:03]
User209218 - Posts: 34
After using TradeStation and Ninja for many years, I am enjoying Sierra. One small issue I have is time of each bar starting and ending. On TS and Ninja, the time of each bar is when the bar ends, but on Sierra, the time is when the bar begins. Is there a way or setting to change the bars to show the time of the bar ending rather than beginning?
Thanks,
[2016-02-26 03:56:03]
No, this is not supported and this capability would never come because it drastically changes how everything works and is implemented and would cause numerous problems as well as difficulties with support because there would be no single way chart bars would be time stamped.
In the future, we may add the capability for a custom study to access the ending time of a chart bar. So if you have a need for something like that, then that capability is coming.
[2016-02-26 04:28:32]
thanks for the quick response.
[2016-02-26 08:04:15]
We can add this capability to the Advanced Custom Study Interface and Language so it is programmatically accessible.
So if there is an interest in that, let us know so we can prioritize it.
