Date/Time: Fri, 27 Dec 2024 18:06:14 +0000
exporting from SC the daily POC
View Count: 867
[2016-02-25 19:57:34] |
User61576 - Posts: 445 |
i want to export the POC (using the numbers bars study) of the daily chart i was trying to user the study "write bar data to file" but it does not write the POC is there any other way to export it? thanks! |
[2016-02-25 22:26:01] |
You should use the Volume Value Area Lines study and you can export the data through the Spreadsheet study: https://www.sierrachart.com/index.php?page=doc/doc_SpreadsheetAdditionalInfo.html#ExportingSheetDataToTextFile Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-02-26 12:17:04] |
worked! thanks!! |
[2016-02-26 18:27:42] |
Please do not provide replies saying thank you.
