Date/Time: Fri, 27 Dec 2024 18:33:25 +0000
User Email
View Count: 708
[2016-02-25 16:16:42] |
Sierra Chart - Max - Posts: 5770 |
Can you please tell me what needs to be enabled to allow the P?L to be seen in this customers DOM? The customer is using TTnet data feed, and is down $50 in trading for the day, but that is not reflected in the DOM P?L window. Thank you.
Sierra Chart Support Date Time Of Last Edit: 2016-02-25 23:02:27
Private File |
[2016-02-25 18:28:00] |
What you are asking about is the Daily Profit/Loss value. For instructions to resolve any problems with it, refer to this page here: https://www.sierrachart.com/index.php?page=doc/doc_DailyProfitLossValue.html In general, the fastest solution is going to be to clear the Trade Activity Log data for the symbol as explained. And then going forward from that point, the calculation should be accurate. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-02-25 23:04:10
