Date/Time: Sun, 19 Jan 2025 09:20:34 +0000
Auto Fib Study
View Count: 3065
[2016-02-25 15:53:59] |
User341584 - Posts: 44 |
Sierra, I enjoy the Auto retracement/projection study. Any way you can program an option to: Display current session only? Thank you for your Time. |
[2017-12-19 17:21:03] |
User787215 - Posts: 14 |
Hello, I have the same requierment for my trading set-up, is it possible to make it ? Best regards Date Time Of Last Edit: 2017-12-19 17:21:22
[2017-12-19 17:51:10] |
So you just want to have like a Number of Days to Calculate setting for that study?
[2017-12-21 08:28:23] |
Yes, I want to use last day high / low to draw fibs (with my selected levels)
[2017-12-21 18:08:16] |
OK we will add a Number of Days to Calculate setting for this study.
[2017-12-27 18:58:59] |
It's so nice of you ! Thank you, tell me when it's ready.
[2017-12-27 20:59:13] |
This has been released in the latest prerelease. Follow the instructions here to update: Software Download: Fast Update Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-03-14 15:14:48] |
User336946 - Posts: 37 |
Hey! Can you add a "fixed time" setting for this? I'd like to always draw a projection based on a single 5min candle.
[2018-04-03 07:46:24] |
Hello, i also would like a "fixed time" for auto fibs it's always re-computing as the time goes. I would like to stay with the fibs of the last day High and Low Also i would like to add like 10 different setting for fibs value Thanks Date Time Of Last Edit: 2018-04-03 08:23:56
