Date/Time: Fri, 27 Dec 2024 17:55:36 +0000
Chartbook, Charts- Problems Loading
View Count: 731
[2016-02-25 15:39:44]
User46911 - Posts: 1
It is taking an inordinate amount of time to get my chartbooks to load, some of the charts within a chartbook will load quickly and others take a very long time OR completely freeze and will not load at all. FYI -This is a very recent problem (last few days)since installing the latest build, #1369....Could you offer some solution for me to correct this problem?
[2016-02-25 18:31:10]
If there is a particular symbol or symbols which Intraday data slowly loads for, the first step we would recommend you do is to delete the Intraday chart data file for them. Follow the instructions here for this:
https://www.sierrachart.com/index.php?page=doc/doc_IntradayDataEditor.html#DeletingDataFile
The next step is to refer to the information in help topic 30:
Http://www.sierrachart.com/index.php?page=doc/helpdetails30.html
