Date/Time: Tue, 11 Mar 2025 07:03:44 +0000
Current Price Line on Independent Scale
View Count: 880
[2016-02-25 12:30:47] |
skelcap - Posts: 139 |
In the attached chartbook in region 2 I want current price line for the cumulative delta bars series which has independent scale to show at the same level, but the scale is different. So how can I get the yellow horizontal current price line to match up with the yellow cumulative delta series in region 2? I still want the main visible scale to be the blue volume bars though.
[2016-02-25 18:09:03] |
The Scale Range of the Current Price Line and Cumulative Delta Bars studies must both be set to "Automatic". Otherwise, this will not work. Refer to: https://www.sierrachart.com/index.php?page=doc/doc_Scaling.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-02-25 19:31:55] |
But if I do that then the volume bars are also forced onto the same scale (see attached). I need the volume stuff on one scale (the main scale) and the delta on another ...
Private File |
[2016-02-25 20:07:59] |
Therefore, it is not possible to do what you want.
[2016-02-25 22:35:45] |
Ah ok that's disappointing. For me it would be very helpful so please consider if it's worth your while to implement. Thank you
