Date/Time: Fri, 25 Sep 2026 01:58:26 +0000
VOW3d-CFD-SMART-EUR-BAAVG
View Count: 1288
| [2016-02-25 10:37:14] |
| User134797 - Posts: 56 |
Hi All I try to dwonload CFD data from Volkswagen or ING Bank For Volkswagen the code is: VOW3d-CFD-SMART-EUR-BAAVG or VOW3-CFD-SMART-EUR-BAAVG, but don,t work For ING Bank the code is: INGa-CFD-SMART-EUR-BAAVG or ING-CFD-SMART-EUR-BAAVG, but don,t work. I can download the stock data for both stocks. My broker is Interactivebrokers. But I need also CFD, because I want trade CFD by using the chart (in Sierra chart: Chart trade mode on). Can somebody help out? Best, Iwan |
| [2016-02-25 10:55:51] |
Refer to CFD Format 2: Interactive Brokers Symbols: CFD Format Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-02-25 10:56:08
| [2016-02-25 12:36:04] |
HI All, I can download the Example in the above link, bu not INGa-CFD-SMART-EUR-BAAVG or VOW3d-CFD-SMART-EUR-BAAVG. Even if I put IB in fornt of the code. Best, Iwan |
| [2016-02-25 18:11:58] |
Use this symbol: INGa-CFD-SMART-EUR From documentation: Use this symbol format to chart and trade a CFD symbol when Interactive Brokers requires the market data for the underlying symbol be requested instead. It is important that when using this symbol format, that there are no other symbols being used within Sierra Chart at the same time for the same CFD symbol with the -BAAVG suffix. Otherwise, you will not receive market data for the symbol.
| [2016-02-26 08:33:48] |
Hi All, I try all the Sierra chart suggestion, but still not working. Did Sierra chart test or try it out?? For me it disappointed. Best, Iwan |
| [2016-03-01 04:00:03] |
No we did not test it but it may not work in our case anyway because of the account that we have for testing. But the CFD symbol formats have been previously tested. At this point contact Interactive Brokers about this following the procedure here: http://www.sierrachart.com/index.php?page=doc/IBSymbols.html#ContactingIBForSymbolSpecifications Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
