Date/Time: Fri, 27 Dec 2024 18:42:34 +0000
Buy & Sell order at the same time.
View Count: 927
[2016-02-25 01:02:57] |
User380978 - Posts: 25 |
Hello, I attached on a picture my "Attached Orders" that I do for my trades, what I need to do, to make a buy and a sell order as well using this strategy in a way that if the buy get filled, the sell cancels automatically and vice versa. Thanks |
oco group.jpg / V - Attached On 2016-02-25 01:02:08 UTC - Size: 62.98 KB - 305 views |
[2016-02-25 04:45:21] |
There are various OCO order types you can use. They are documented here: https://www.sierrachart.com/index.php?page=doc/doc_OrderTypes.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
