Date/Time: Wed, 16 Sep 2026 22:34:56 +0000
ACSIL Plotting Multiple Indicators
View Count: 1487
[2016-02-24 18:00:51]
molandes1 - Posts: 8
Hello Support,
Is it possible to use the "Enable" function to plot multiple indicators on a chart when I have enabled set to yes?
Example: I am trying to build a custom study to plot the VWAP (Volume Weighted Average Price) and the Bid/Ask Difference bars onto my chart when "Enabled" is set to "Yes".
Please advise. Thanks!
[2016-02-24 18:58:32]
We have no idea what you are referring to here.
What is "Enabled"?
[2016-02-24 20:29:04]
For example:
{if (!Enabled.GetYesNo())
// use code to add VWAP and Bid/Ask Difference Bars studies to chart here.
[2016-02-24 20:36:55]
This is a programming question. You will have to program what you want and see how it works.
[2016-02-24 20:52:34]
Is there not an intermediate study function for the vwap like there is for most other indicators? Or do I have to put the whole block of core function code in for the vwap to make this work?
[2016-02-25 05:31:06]
No, the Volume Weighted Average Price is a fairly complicated study. There is no intermediate study calculation function for it.
But we will see if we can add it. It might be possible.
[2019-07-19 11:12:54]
User722856 - Posts: 81
Dear Sirs,
Are there any plans to add the "Volume Weighted Average Price" to the "ACSIL Interface Members - Functions" so that it would be easier to use it in ACSIL?
Thanks.
Best regards
[2019-12-26 13:23:28]
FerroTrader - Posts: 72
Hello.
Is it possible to add vWAP as ACSILS Interface Member function, please ?
Thanks a lot.
