Date/Time: Wed, 02 Sep 2026 08:10:36 +0000
Retrieving caption of Control Bar Button using ACSIL
View Count: 1070
| [2016-02-23 21:08:43] |
| User542105 - Posts: 4 |
I would like to know how can i get the caption of a user control bar button in a custom study. I need to dynamically change the captions of a user button using different information contained in each study instance. If this is not possible, then how do i detect which chart in a chart book is active or not so i can set the buttons with the captions i want depending on each study instance? |
| [2016-02-24 03:49:52] |
The first request is not supported. For the second request, we will add this to the next version: sc.ChartWindowIsActive It will have a value of 1 if the chart window is the active window. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
