Date/Time: Fri, 27 Dec 2024 17:57:57 +0000
Historical data problem EurUsd futures
View Count: 782
[2016-02-23 17:03:29]
User51760 - Posts: 108
Dear Support Team,
I am using SC from my personal account and Infinity Charts. The data problem happens with Infinity Charts. InfinityFutures support told me to talk to you.
Probably I am doing something wrong: under Sierra Chart 1371 and InfinityAT and TransAct data in
E7H6 I do not receive any historical data for intraday charts, only back-adjusted continuous data for the historical daily chart.
In M6EH6 it is the other way around: I am receiving proper intraday data, but no historical data for the daily chart.
6E
H6 brings up everything perfectly.
All charts have the exactly same settings.
Any idea what I am missing?
Thank you for your consideration,
Best,
Chris
imageM6E_1.png / V - Attached On 2016-02-23 17:01:29 UTC - Size: 70.71 KB - 270 views
imageE7.png / V - Attached On 2016-02-23 17:01:46 UTC - Size: 90.91 KB - 287 views
[2016-02-23 18:15:18]
Update the Symbol Settings as explained here:
https://www.sierrachart.com/index.php?page=doc/doc_GlobalSymbolSettings.php#UpdateSettingsSteps
We corrected the problem with the E7 historical Intraday data for TransAct. Otherwise, we see no other issues.
For missing Intraday data, refer to:
https://www.sierrachart.com/index.php?page=doc/doc_HistoricalIntradayData.html
For missing Historical Daily chart data, refer to help topic 6:
Http://www.sierrachart.com/index.php?page=doc/helpdetails6.html
